20 Most Recent Kicker CVR12 Car Subwoofer Questions & Answers
How to hook up from post to post
if u have two pos. and two neg. on the back just run a wire from one pos to the other pos and do the same with the neg just run the wire from the box to one of the pos and neg only on one side u have two wires runing to them
2/12/2024 9:25:10 AM • Kicker CVR12 Car... • Answered on Feb 12, 2024
Comp12
1.75 cubic feet to 3.25 cubic feet or go to the kicker website and get some ideas on box building. Pick a style. Have fun
2/20/2015 9:19:38 AM • Kicker CVR12 Car... • Answered on Feb 20, 2015
How do I properly wire 2 12 inch 40 cwr122 subs to
Need to know the resistance of the speakers you are wiring, are they 4 ohm or 8 ohm speakers? Is this for car or home audio? What resistance does the amp show it is capable of handling?
10/15/2013 11:14:10 PM • Kicker CVR12 Car... • Answered on Oct 15, 2013
Is my amp going to be powerful enough for my kicker 12
If sub is dual coil and amp is 2ch then connect the sub woofer one side on 1&2 terminal and 2nd side on 3&4 terminal of the Amp.
4/21/2012 12:03:43 PM • Kicker CVR12 Car... • Answered on Apr 21, 2012
My subwoofer stops when volume is increased
have u check the radio out do u have an eq
3/20/2012 4:58:23 AM • Kicker CVR12 Car... • Answered on Mar 20, 2012
3answers
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
12/3/2011 7:53:43 AM • Kicker CVR12 Car... • Answered on Dec 03, 2011
2answers
Why is there 4 termanals on the back of my speaker
it is a dual voice coil subwoofer.
4/14/2011 5:34:41 AM • Kicker CVR12 Car... • Answered on Apr 14, 2011
Can i run 4 dual 2 ohm cvr 12's on a kicker
Yes you can if you run them each as 4ohms. Running them at 1ohms will most likely overload the amp.
4/13/2011 11:02:21 PM • Kicker CVR12 Car... • Answered on Apr 13, 2011
My (2) 12 in kicker
turn down the gain and the preout in the head if it supports it. also turn down the frequencey to 80. also dont over shoot the speaker by turrning up the bass on the head unit and then turning up the volume.
3/8/2011 9:25:25 PM • Kicker CVR12 Car... • Answered on Mar 08, 2011
My bass isn't clear anymore. it sounds cheap and
Distortion of sound is commonly caused by a leaky electrolytic filter capacitor.
Your unit need to send to repair shop because it is quite technical diagnosing the faulty capacitor.
Also dry joints are going to consider because it will produced the same problem as what you encountered right now.
This is fixable anyway.
Thanks for using fixya.
Pls rate my help.
1/19/2011 12:47:18 AM • Kicker CVR12 Car... • Answered on Jan 19, 2011
What is proper air amount
2.25- 2.50 cu. ft box sealed or ported.
1/17/2011 5:37:33 AM • Kicker CVR12 Car... • Answered on Jan 17, 2011
2answers
How do i fix a bust subwoofer speaker...
replace it or sent back to manufacturer for warranty if still applies to product.
11/25/2010 7:34:58 AM • Kicker CVR12 Car... • Answered on Nov 25, 2010
Kicker CVR12 Car Subwoofer Logo
Popular Tags
125 questions posted
Top Kicker Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kicker Car Audio & Video
Most Popular Question
cvr 15 kiker bumoing
  • Car Audio & Video
