Cisco VPN
Upgrade your router to the latest firmware. You can download firmware at
http://www.dlink.com.au/tech/ .
Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Configuring PC running VPN Client Software:
Step 1 Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Step 2 Change IP Address to be outside of the routers DHCP Pool (i.e. 192.168.0.99). By default the DHCP pool is 192.168.0.100 - 192.168.0.199.
Step 3 Configure Cisco VPN Client - Connection Properties.
Step 4 Check Enable Transparent Tunneling.
Step 5 Allow IPSec over UDP ( NAT/PAT).
Configuring Router using the Web-based configuration:
Step 1 Open the Web Configuration Page by entering 192.168.0.1 into your web browser. Enter username (admin) and your password (blank by default).
Step 2 Check the Status tab and make sure that you are running the latest version of firmware. If not, upgrade firmware before proceeding.
Step 3 Click on the Miscellaneous button on the Tools tab. Enable both PPTP and IPSec.
Step 4 Click Apply.
Step 5 Click on the Virtual Servers button on the Advanced tab.
Step 6 Enable IPSec from the list and configure as follows:
Private IP: IP Address of the PC running Cisco VPN Client
Protocol: UDP
Private Port: 500
Public Port: 500
Schedule: Always.
Step 7 Click Apply and then Continue.
Step 8 Enable PPTP from the list and configure as follows:
Protocol: TCP
Private Port: 1723
Public Port: 1723
Schedule: Always.
Step 9 Click Apply and then Continue.
http://www.dlink.com.au/tech/default.asp?model=DI-524UP
