20 Most Recent
Dell PowerEdge SC 1430 (bscwfk1) Dual Core Intel Xeon 5110; 4MB Cache, 1.6GHz, 1066MHZ FSB 80GB/1000... Server Questions & Answers
I have problem with my
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Remove all PCI cards and see if you see if it powers on. Check USB ports too.
Error 123
There are 3 step to repair 123 error
If you got 123 error then there is a 94% chance that your computer has registry problems. To repair 123 error you need to follow the steps below:
* Step 1 - Download a 123 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 123 error.
Here are the url of 123 error repair tool:http://www.RepairErrorFast.com/ttfix-123...
Source(s):
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
Dell Poweredge 2900 I912 SEL FULL
Best is to find a support or systems engineer on http://www.qual.ch if you are in Switzerland and for the UK you can find find a top Dell expert or systems specialist on http://qualifind.co.uk -- I just asked one (from Qualifind) and was informed you just need to install Openmanage and clear the logs from there, no need to down the server.
