20 Most Recent Dell PowerEdge 6950 (becwlk1_3) Server Questions & Answers
  • Seagate does not supply drivers for SATA drives because hard drives themselves do not require specific device drivers. Operating systems such as Windows XP/2000 may not automatically recognize the SATA controller in the system. This is especially true if the hardware is newer than the operating system.
  • Try ti find the exact driver for another O/S then install it in "compatibility mode" , it may work so
Dell PowerEdge... | Answered on Jan 24, 2019
Computer not recognizing the hard drive. Look in BIOS to see if hard drive is listed. Reload system disc/CD.
Dell PowerEdge... | Answered on Mar 14, 2016
It could be a couple of things 1. the computer Cpu fan is not working or is clogged inspect it and clean or replace.2 The power supply could be bad
Dell PowerEdge... | Answered on Jun 14, 2015
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Dell PowerEdge... | Answered on Oct 01, 2014
www.hp.com/support
Dell PowerEdge... | Answered on Aug 18, 2014
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Dell PowerEdge... | Answered on Aug 08, 2014
You will have to get into the controlled setup in order to find out what the problem is, or you can simply hit ctrl-D and do the Dell disk diagnostics which will take an hour or more, but will give you an idea of where to start.
Logically, if it won't boot, then your RAID is probably broken. it can sometimes be repaired through either the RAID or controller setup menu, which you can see during boot.
go here, for the manuals and documentation on how to do that: http://www.dell.com/support/home/us/en/19/product-support/product/poweredge-t105/manuals
Dell PowerEdge... | Answered on Jun 04, 2014
what is your server model? in most cases you can use the operating disc to format the server drives
Dell PowerEdge... | Answered on Apr 04, 2014
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
Dell PowerEdge... | Answered on Mar 27, 2014
Best is to find a support or systems engineer on http://www.qual.ch if you are in Switzerland and for the UK you can find find a top Dell expert or systems specialist on http://qualifind.co.uk -- I just asked one (from Qualifind) and was informed you just need to install Openmanage and clear the logs from there, no need to down the server.
Dell PowerEdge... | Answered on Jan 09, 2014
Dell PowerEdge 6950 (becwlk1_3) Server Logo
Popular Tags
1 questions posted
Clive
Clive
Alun Cox
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
cordial saludo tengo un servidor dell
  • Computers & Internet
