20 Most Recent Dell PowerEdge 2900 (becwdk1_7) Dual Core Intel Xeon 5130, 4MB Cache, 2.00GHz, 1333MHz FSB 300GB/200... Server Questions & Answers
Ma dell poweredge cant boot
try reinserting RAM or Rebuid RAID again..hope this helps ....
3/8/2011 4:00:04 PM • Dell PowerEdge... • Answered on Mar 08, 2011
No Boot device available Press F1 to reboot
Computer not recognizing the hard drive. Look in BIOS to see if hard drive is listed. Reload system disc/CD.
3/14/2016 4:54:22 AM • Dell PowerEdge... • Answered on Mar 14, 2016
2answers
I t will satrt up an run but computer keep shuiting down
It could be a couple of things 1. the computer Cpu fan is not working or is clogged inspect it and clean or replace.2 The power supply could be bad
6/14/2015 2:48:41 AM • Dell PowerEdge... • Answered on Jun 14, 2015
Power is 2950 i912 sel full
Namrata_stha, The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ } Where with Server 2003 you can go tot he Event viewer and clear it. Let me know if this helps.
10/1/2014 4:05:30 PM • Dell PowerEdge... • Answered on Oct 01, 2014
Configure remote start
www.hp.com/support
8/18/2014 7:10:29 PM • Dell PowerEdge... • Answered on Aug 18, 2014
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
8/8/2014 5:00:58 PM • Dell PowerEdge... • Answered on Aug 08, 2014
Dell poweredge t105 freezes at boot
You will have to get into the controlled setup in order to find out what the problem is, or you can simply hit ctrl-D and do the Dell disk diagnostics which will take an hour or more, but will give you an idea of where to start. Logically, if it won't boot, then your RAID is probably broken. it can sometimes be repaired through either the RAID or controller setup menu, which you can see during boot. go here, for the manuals and documentation on how to do that: http://www.dell.com/support/home/us/en/19/product-support/product/poweredge-t105/manuals
6/4/2014 8:25:56 AM • Dell PowerEdge... • Answered on Jun 04, 2014
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
4/4/2014 2:12:18 PM • Dell PowerEdge... • Answered on Apr 04, 2014
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
3/27/2014 3:52:28 PM • Dell PowerEdge... • Answered on Mar 27, 2014
0answers
Dell Poweredge 2900 I912 SEL FULL
Best is to find a support or systems engineer on http://www.qual.ch if you are in Switzerland and for the UK you can find find a top Dell expert or systems specialist on http://qualifind.co.uk -- I just asked one (from Qualifind) and was informed you just need to install Openmanage and clear the logs from there, no need to down the server.
1/9/2014 9:50:00 AM • Dell PowerEdge... • Answered on Jan 09, 2014
I have a Dell PowerEdge 1300 server and for the
You can download the service manual from Dell`s website or either check some youtube tutorials if available.
11/4/2013 2:16:05 PM • Dell PowerEdge... • Answered on Nov 04, 2013
My Dell Poweredge 1550 won't connect to the
Is it in a 1, 3, 2 beep pattern (beep....beep, beep, beep........beep, beep)? If so, the memory is either not seated well or may be bad. Try reseating your memory. If it continues, try with one stick at a time just to see if it will boot up with a display.Thanks,--Brian
11/2/2013 10:35:05 PM • Dell PowerEdge... • Answered on Nov 02, 2013
Dell PowerEdge 2900 (becwdk1_7) Dual Core Intel Xeon 5130, 4MB Cache, 2.00GHz, 1333MHz FSB 300GB/200... Server Logo
1 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
ma dell poweredge boot
  • Computers & Internet
