20 Most Recent Northstar 10 HP 6500/6120 Watt Diesel Generator Questions & Answers
I have an old northstar 2400 generator, output voltage is half of what it should be. parts do not show brushes so any idea where brushes would be
If there are no brushes in the parts list then it is brushless. It will have a capacitor in the 10 to 20UFD range that regulates excitation current. Most likely the capacitor is out of tolerance but can be other causes.
1/4/2022 4:24:07 PM • Northstar... • Answered on Jan 04, 2022
Northstar diesel generator 6500 main bracker tripping at low charge
Tripping phenomenon A.Ifdiesel gensetoperates under rated conditions for a few minutes, the automatic air switch trips, after recloses, then trips a few minutes later with a burning odor. The cause: The main contact of the automatic air switch is not well contacted or the spring pressure is insufficient. and the lead-out wire of the switch is not well contacted. The above two reasons will increase the contact resistance of the main circuit of the automatic air switch and cause serious fever, which will lead to the action of the thermal release and lead to wrong tripping. Methods of resolution: At this time, we should clean the main contacts of the automatic air switch and flatten them with a fine file or fine sandpaper; Adjust contact spring pressure to make good contact; clean contacts, apply conductive paste if necessary, and lock connection screw.
1/3/2020 3:49:43 AM • Northstar... • Answered on Jan 03, 2020
A Northstar generator, 10,500 watt. What controls the output voltage
a voltage regulator that controls the field winding voltages
9/2/2017 11:21:59 PM • Northstar... • Answered on Sep 02, 2017
My northstar 10500 generator runs but no power at outlets, I had the capacitors replaced and still no power? Where on the web can I find a diagram of this unit.
Did you try the capacitor wired up both ways around? They only go one way and there is no indication as to which on it. If you still have trouble you need to flash it. Contact us if you need more info on flashing the unit (DO NOT USE A BATTERY OR MAINS TO DO SO!)
2/22/2017 2:14:13 PM • Northstar... • Answered on Feb 22, 2017
2answers
I own a northstar pro 80000 generator. I recently had to replace both capacitors. Now reading 145 and 148 volts per side. Any adjustments available to reduce? Thank you in advance, Mark
The RPM lowered should lower voltage, try it by hand, plug in the volt meter and push the throttle on top of carb with your finger ,should not take much .
1/17/2017 12:32:35 PM • Northstar... • Answered on Jan 17, 2017
Northstar 5500 watt generator lost power to outlets and is squealing loud at the generator side of unit, there is no switch for output
squealing either bearing,bushing or winding going or gone if bushings or bearings might be able to repair if not to damaged
8/29/2016 10:44:02 PM • Northstar... • Answered on Aug 29, 2016
The rubber gasket on bottom of gas tank where fuel line exits is torn and leaking. The valve is fine.
You cannot just buy that gasket, but will need to purchase a new Fuel Tap Petcock. You can purchase it here: http://www.generatorguru.com/northstar/
9/25/2015 11:36:52 AM • Northstar... • Answered on Sep 25, 2015
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
the unit has gone into over load The total power requirement has exceed the output of the generator for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit. when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
4/13/2015 6:18:49 AM • Northstar... • Answered on Apr 13, 2015
I have a northstar generator that runs but not putting out any power
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
3/1/2015 9:40:11 PM • Northstar... • Answered on Mar 01, 2015
0answers
0answers
Turn key to start hear hum and starter wont turn
Check for engine lock down due to sitting make sure it is free with plugs out. Check starter solenoid after you make sure battey voltage and battery are good
11/17/2013 3:03:17 PM • Northstar... • Answered on Nov 17, 2013
Northstar Model 13000 ppg generator 165923L s/n 05
bbbbbbbbbb
9/21/2013 2:29:22 PM • Northstar... • Answered on Sep 21, 2013
My generator is not putting
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
8/10/2010 12:11:03 AM • Northstar... • Answered on Aug 10, 2010
Northstar 10 HP 6500/6120 Watt Diesel Generator Logo
1 questions posted
Top Northstar Electrical Supplies Experts
Sean Wright
Sean Wright
john h
CJ Rock
CJ Rock
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Northstar Electrical Supplies
Most Popular Question
old northstar 2400 generator output
  • Electrical Supplies
