20 Most Recent
Caterpillar D399 Generator Drive Engine Questions & Answers
Why does it start, then shuts down?
operator_13 answered about a year ago
I'm gonna say there's a problem with the system ground....undo the lug that connects to the chassis ground and wirebrush that lug...and the space where it bolts to, think that insufficient ground to the relay box has the relays dropping out....combined with a battery that may be older than five years old has led to a relay dropping out....the fuel pump or ignition relay is not seeing sufficient voltage to stay engaged....test at the relay box for GROUND...and varying voltages from the corrosion that is holding up the show~
Engine has air supplied starter and has no air in
Are you able to crank it?Also check the engine block heater for functionality. It won't start else. Also I am assuming all fuel lines are primed? try cracking the fuel line to each injector as you crank it, and make sure the fuel delivery pump is working, This will also bleed the air from the system.
Vernorhaving overspeed problem with a caterpillar generator
When we use diesel generator set, it maybe a overspeed problem, this is a special fault, it will not only cause serious damage to spare parts, but also may endanger personal safety.
Under normal operation, the engine speed suddenly rises, so that the engine speeds up beyond the rated speed and loses control, and emits a huge roar, the exhaust pipe emits a lot of black smoke or blue smoke.
Here is some reasons:
Faults of injection pump and speed regulator
Additional fuel enters the combustion chamber
There are many reasons causing generator overspeed. You need to check and remove resaons one by one.
More generator technology supports, contact us: [email protected]. We are ont only a diesel generator manufacturer, but also provide supports.
RPM Caterpillar generator not stable. Any solutions ? Thanks
problem with the governor controls
if electronic controlled governor it could be the electronic system is faulty
If manual control , check for governor lever operation
check for fuel flow problems , blocked filters , low fuel level vent ing for the fuel tank blocked
