20 Most Recent Caterpillar 3412E DITA Marine Propulsion Engine Questions & Answers
HOW TO MAKE VALVE SETTING FOR CAT 3412
i don't have answer to my question how to valve lash the Cat engine 3412 Generating set
7/9/2015 1:13:42 PM • Caterpillar... • Answered on Jul 09, 2015
Caterpillar 3412e valve lash adjustment
Contact JD Marine in Fort Lauderdale FL they can possibly get you the information, or sell you a service manual
11/17/2013 11:31:25 PM • Caterpillar... • Answered on Nov 17, 2013
What may cause inlet manifold not taking air
PLUGGED AIR FILTER
10/3/2021 8:30:21 PM • Caterpillar... • Answered on Oct 03, 2021
Vernorhaving overspeed problem with a caterpillar generator
When we use diesel generator set, it maybe a overspeed problem, this is a special fault, it will not only cause serious damage to spare parts, but also may endanger personal safety. Under normal operation, the engine speed suddenly rises, so that the engine speeds up beyond the rated speed and loses control, and emits a huge roar, the exhaust pipe emits a lot of black smoke or blue smoke. Here is some reasons: Faults of injection pump and speed regulator Additional fuel enters the combustion chamber There are many reasons causing generator overspeed. You need to check and remove resaons one by one. More generator technology supports, contact us: [email protected]. We are ont only a diesel generator manufacturer, but also provide supports.
9/21/2019 6:53:38 AM • Caterpillar... • Answered on Sep 21, 2019
2answers
I have a caterpillar D399. The oil and water are getting as one. What should the mechanic do?
You will get all the information about your caterpillar D399 from here https://big-manuals.com/products/d399-industrial-engine-workshop-service-repair-manual. Download your copy today!
6/25/2019 11:59:05 AM • Caterpillar... • Answered on Jun 25, 2019
Keypad doesn't work on caterpillar powercube hc-5128 .. need wiring schematic and cannot find one
Hello Gloria Moslander, My digging around shows that unit is not actually a CAT but a TRIDAKO, 6000 watt, 2 cylinder... (FRAME MOUNTED AUX POWER UNIT (am I close?)). Company Details: 5610 Perkins Road POB 740 Alliance, NE 69301USA Phone: 1-308-762-3235 Toll Free: 1-866-526-7109 http://www.tridako.com Registration required to get anywhere... Request More Information HC5128 PowerCube APU VehicleServicePros com PowerCube APU Service
5/29/2016 7:52:08 AM • Caterpillar... • Answered on May 29, 2016
RPM Caterpillar generator not stable. Any solutions ? Thanks
problem with the governor controls if electronic controlled governor it could be the electronic system is faulty If manual control , check for governor lever operation check for fuel flow problems , blocked filters , low fuel level vent ing for the fuel tank blocked
5/28/2016 3:54:35 AM • Caterpillar... • Answered on May 28, 2016
Serial numbers *ae a00348*
whats question about generator
9/4/2014 1:33:57 AM • Caterpillar... • Answered on Sep 04, 2014
Low speed
Is your CHOKE still on? Is your Actuator Cable still connected?
7/3/2014 3:09:58 AM • Caterpillar... • Answered on Jul 03, 2014
Control wiring schematic drawing
What model CAT?
6/27/2014 9:13:01 AM • Caterpillar... • Answered on Jun 27, 2014
0answers
Caterpillar 3412E DITA Marine Propulsion Engine Logo
Popular Tags
3 questions posted
Top Caterpillar Electrical Supplies Experts
deton8 von Splosion
CJ Rock
CJ Rock
ADMIN Eric
ADMIN Eric
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Caterpillar Electrical Supplies
Most Popular Question
caterpillar 3412e valve lash adjustment
  • Electrical Supplies
