20 Most Recent Coleman Powermate 1,850 W Portable Generator Pm0401853 Questions & Answers
PM0621512 15000W Coleman Generator not starting
An OVERCRANK fault implies no start after three attempts. Most likely a fuel issue.
11/25/2023 1:26:24 PM • Coleman... • Answered on Nov 25, 2023
I am looking for an owners manual for a Coleman gasoline powered 120/220 generator
Coleman is now Powermate.
https://www.powermate.com/generators/portable-generators
Post model number and likely someone will comment with a URL address of the manual.
11/2/2023 10:40:38 PM • Coleman... • Answered on Nov 02, 2023
Coleman Vertex 5500 Generator. Where is the starter solenoid on it please.
Question edited for clarity and spelling errors. Follow the heavy gauge positive wire from the battery. It is shown in the link. https://www.google.com/search?q=Coleman+Vertex+5500+Generator.+Where+is+the+starter+solenoid and https://www.google.com/search?q=coleman+vertex+5500+generator.+starter+solenoid+replacement ..
7/29/2023 5:46:15 PM • Coleman... • Answered on Jul 29, 2023
What is/would be the price for a replacement motor for a coleman powermate aircompresser
Not sure which unit you have as they make several. But here's some sites to check out.. https://www.google.com/search?q=coleman+powermate+air+compressor+motor
7/28/2023 6:45:22 PM • Coleman... • Answered on Jul 28, 2023
2answers
How to remove a rusty fuel tank for cleaning
When dealing with specific equipment like the Coleman Powermate Pro 6750 generator, it's important to follow proper procedures and consult the manual for disassembly instructions. However, I can provide some general guidance:
  1. Look for hidden screws or fasteners: Check for any additional screws or fasteners that may be securing the plastic control panel to the generator frame or the fuel tank. These may not be immediately visible or obvious.
  2. Disconnect electrical connections: Before attempting to remove the control panel, make sure to disconnect any electrical connections that may be attached to it. These could include wires or connectors for the generator's controls, switches, or displays.
  3. Release clips or tabs: Some control panels may have clips or tabs that hold them in place. Look for any release mechanisms that may need to be pressed or disengaged to remove the panel.
  4. Seek guidance from the manufacturer: If you don't have the manual or are unsure about the disassembly process, it's recommended to contact Coleman Powermate customer support or visit their website. They can provide you with the specific instructions or guide you through the steps needed to remove the control panel and access the fuel tank.
Remember to exercise caution and prioritize your safety when working with equipment like generators. If you are uncomfortable or uncertain about the process, it's best to seek professional assistance or consult a qualified technician to avoid any potential damage or harm.
6/18/2023 5:01:58 PM • Coleman... • Answered on Jun 18, 2023
Manual for Coleman Powermate Pro 6750 Generator model PM0606750
google coleman powermate pro 6750 manual copy and paste link https://manualsbrain.com/en/manuals/1408153/
6/17/2023 4:24:58 PM • Coleman... • Answered on Jun 17, 2023
Coleman pm1500 started it up plugged in extension cord to much load killed motor now getting no fire from engine
It sounds like your Coleman PM1500 generator may have experienced a serious issue due to overloading, which may have caused damage to the engine or electrical system. To troubleshoot the issue and restore power to the engine, you may want to try the following steps:
  1. Check the oil level and fuel level: Make sure that the oil level in the engine is sufficient and that the fuel tank is not empty.
  2. Check for any visible signs of damage: Check the generator's components, including the engine, spark plug, and electrical system, for any visible signs of damage or wear.
  3. Test the spark plug: Remove the spark plug and inspect it for damage or fouling. If it appears to be damaged or fouled, replace it with a new one.
  4. Check the electrical system: Use a multimeter to check the voltage output of the generator's electrical system. If the voltage is low or non-existent, there may be an issue with the generator's alternator or voltage regulator.
If you are unable to diagnose and fix the issue yourself, it may be best to take the generator to a qualified repair technician who can help you identify and address the problem.
3/19/2023 3:14:05 PM • Coleman... • Answered on Mar 19, 2023
2answers
Trying to wire in the outlets on my generator
power mate 8000 series.no model told or serialmoved this to generatorsask maker for help, or seller the GEN is country specific, none told.moved this post generators..
3/19/2023 3:11:02 PM • Coleman... • Answered on Mar 19, 2023
Coleman Powermate starts but dies after 10 seconds
It sounds like you've already done a lot of troubleshooting, but here are a few more things to check:
  1. Spark Plug: Check the spark plug for any visible damage or deposits, replace if needed. Make sure it is tightened properly and there is a strong spark when cranking the engine.
  2. Fuel Filter: Check the fuel filter for any clogs or debris, replace if needed.
  3. Air Filter: Check the air filter for any damage or clogs, replace if needed. A dirty air filter can restrict air flow to the engine and cause it to stall.
  4. Vacuum Leaks: Check for any vacuum leaks in the fuel system, this can cause the engine to run poorly and stall.
  5. Governor System: The governor system regulates the speed of the engine. If it's not functioning properly, the engine may stall. Check the governor arm, linkages, and springs for any damage or looseness.
  6. Ignition System: Check the ignition system, including the ignition coil and ignition module, for any signs of damage or wear. Replace if necessary.
  7. Fuel Pump: Check the fuel pump for proper operation, the fuel pump may be failing and not delivering enough fuel to the engine.
These are just a few possibilities, and it's best to consult the owner's manual or a professional mechanic to diagnose and repair the issue.
2/13/2023 5:53:52 AM • Coleman... • Answered on Feb 13, 2023
I need an owners electrical manual for a 2012 coleman 30' 5th wheel
notify colman ---or an rv shop/dealer --
2/10/2023 3:44:36 PM • Coleman... • Answered on Feb 10, 2023
I have a coleman powermate 5500 series generator powered by a yamaha mz 300 need whole wiring diagram
talk to a specialist at this linkhttps://www.justanswer.com/
1/18/2023 8:02:00 PM • Coleman... • Answered on Jan 18, 2023
Coleman Powermate 1,850 W Portable Generator Pm0401853 Logo
Popular Tags
8 questions posted
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Electrical Supplies
Most Popular Question
coleman power mate pm400911 home standby
  • Electrical Supplies
