20 Most Recent
3Com 3CSFP91 Transceiver Questions & Answers
Connecting a 3Com 2952 Plus switch to a Cisco 3750 switch
If you also have a standard copper cable (or a second fibre cable) connecting the two switches (for resilience perhaps?), this issue is probably being caused by something called Spanning Tree. This is implemented on switches as a 'loop avoidance' system, and can look like you have described with one end 'ip' and the other end no lights.
On the Cisco switch, get to a telnet/ssh/console session, log in and enter show spanning-tree and press enter.
have a look to see if the fibre interface has a status (sts column) of BLK. If it has, then this is called 'blocking' and will remain like that until you remove the second link to the other switch.
Hope that this has helped!
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
