20 Most Recent RCA ION-ITTUSB05 Turntable Questions & Answers
How do i change the needle
Put one in
4/11/2014 5:10:46 PM • RCA ION-ITTUSB05... • Answered on Apr 11, 2014
2answers
How to use usb to rca cable - Driver
That cable will not allow you to view your computer on your TV.
If you have S-video, DVI, HDMI or VGA out on your computer AND the corresponding port on your TV, then you should be able to fairly easy. What TV & computer do you have?
11/5/2011 8:46:01 PM • RCA ION-ITTUSB05... • Answered on Nov 05, 2011
How do I remove the
Lift the rubber mat off the platter and notice the two large holes for your fingers to fit into. Simply lift the platter off the base by pulling.
3/18/2011 6:44:20 AM • RCA ION-ITTUSB05... • Answered on Mar 18, 2011
Sounds from turntable
There will be some feedback from the turntable, and this is totally normal. Ive actually heard the music from the needle itself, and is nothing to worry about
8/18/2010 3:39:34 PM • RCA ION-ITTUSB05... • Answered on Aug 18, 2010
3answers
Turntable does not rotate when switched 'on'.
Throw it from a second story window then smash it with a sledgehammer. That's what I plan to do with mine.
6/3/2010 8:43:13 AM • RCA ION-ITTUSB05... • Answered on Jun 03, 2010
0answers
Plate leans to one side, dragging base as it turns
Ship it straight back, but get an RMA first if you bought it on-line.
If its from a shop same deal take it back and ask for another (do not accept it being repaired)
I understand that when we get a new toy we want to play. But I would hate to play with a new toy that I knew was repaired from new. That would take a lot of the pleasure out of it.
8/18/2009 3:16:15 PM • RCA ION-ITTUSB05... • Answered on Aug 18, 2009
I have a RCA 5 DISC CHANGER STEREO now i have lost
Ipods are not very user's friendly, using usb to hook up on your system needs a lot ot processing. The simplies way is to use a pair of 3.5mm - RCA patch cord, connect to AUX. or AUDIO IN jack
8/16/2009 1:45:07 AM • RCA ION-ITTUSB05... • Answered on Aug 16, 2009
ION USB turntable working famously
Thanks for contacting Fixya.
iTune version 8.0 is not compatible or understood by Vinyl converter. I would request you to please uninstall it and install an older version so that it starts recognising the Vinyl converter and iTune starts recognising it.
God Bless.
7/15/2009 9:10:36 PM • RCA ION-ITTUSB05... • Answered on Jul 15, 2009
How do i connect the pyle pslsw6 power amp to my av receiver, there are no rca jacks on the power amp.?
google Banana Plug to RCA Speaker Cable eBay $5.00 look at amazon amazon has 3 feet long cable. you can use RCA to bare wire cables and use binding posts on back of item.
2/21/2024 5:48:18 PM • RCA Audio... • Answered on Feb 21, 2024
3answers
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM • RCA Audio... • Answered on Jan 15, 2024
Looking for power supply for RCA RTD 317
The power supply is internal.
11/5/2023 8:35:31 AM • RCA Audio... • Answered on Nov 05, 2023
RCA Digital Voice Recorder RP 5120 won't unlock?
Question edited for clarity. The words 'want' and won't are interchangeable. Question moved from Cars and Trucks category. It appears to be a well known issue. https://www.google.com/search?q=RCA+Digital+Voice+Recorder+RP+5120+won%27t+unlock ..
9/29/2023 5:50:33 PM • RCA Audio... • Answered on Sep 29, 2023
My Kenwood A-94, the front selector buttons have no effect, , does it have to do with IC TC9163N?
TC 9163N is connected with Rec Out. TC 9164N and TC 9215P are the Audio Input Selector.
9/24/2023 11:57:46 AM • RCA Audio... • Answered on Sep 24, 2023
Sherwood receiver and a Sherwood equalizer, need to know how to hook them up together
Receiver OUT to Equalizer IN and off to the speakers. Or look up make model manual on both of them. https://www.google.com/search?q=sherwood+receiver+manual
Sherwood RX-4109 Operating Instructions Manual
ManualsLib https://www.manualslib.com > ... > RX-4109 View and Download Sherwood RX-4109 operating instructions manual online. Am/Fm Stereo Receiver. RX-4109 stereo receiver pdf manual download.
Sherwood RX-4109 user manual (English - 18 pages)
Manuals.ca https://www.manuals.ca > receivers > Sherwood User manual. View the manual for the Sherwood RX-4109 here, for free. This manual comes under the category receivers and has been rated by 3 people with an ... ..
9/21/2023 4:42:44 AM • RCA Audio... • Answered on Sep 21, 2023
RCA ION-ITTUSB05 Turntable Logo
21 questions posted
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
remove
  • Audio Players & Recorders
