20 Most Recent
CyberPower (CPS1500AVR UPS) (CPS1500AVR UPS) UPS System Questions & Answers
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
300 watt manual
Your not asking the right question. The answer is dependent upon how long you want the backup to work. Does a battery fit in the unit or is it alone? If you were to connect a car battery to the unit it would run for many hours, say a motorcycle battery would run maybe an hour. It is all about the time you want for run time.
Shutting off
What is the UPS displaying prior to shutting down? How old is the UPS? Did you change the batteries? Need as much info as you can give to help you.
