20 Most Recent
Airlink AWLH3026T 802.11g/b Wireless Adapter Questions & Answers
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
- Click Start, Run, and type ncpa.cpl, and then click Ok.
- Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
- Click the Wireless Networks tab.
- Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
4/29/2009 12:41:03 AM •
Airlink...
Answered
on Apr 29, 2009
Wireless not picking up
at first your card its detected or not if not then replace it if yes then go to the right click to my computer there option is there manage in that device management is there in that your card has yellow mark in the other option just double click on it then re-installed the driver option is there put the card and the cd in the computer then you get it
4/2/2009 9:08:05 AM •
Airlink...
Answered
on Apr 02, 2009
Open nat type
I take this is your type of network you have. NAT (Network Address Translation) only job is make all the IP's of you LAN to be able to use the one IP From the ISP. For example, you can have 3 Pc's connected to router (192.168.1.1 to 192.168.1.3) with only one connection to ISP, and address like 67.123.43.200 (Address change upon ISP location).
In order to the game communicate between PC ans Internet have to configure Ports to connect to. Thanks to UPNP (Universall Plug and Play) this configuration is made automatically between the PC and the Router and simplifies those configurations.
Things to check:
The router have UPNP and is on.
There's a Firewall interfering with the game.
1/11/2014 3:18:06 PM •
Airlink...
Answered
on Jan 11, 2014
Forgot password
router passwords are usually on the bottom of the router. sometimes it is the serial number. if that doesn't help, then if your router is unlocked, you can log into it and find the wifi password in the wireless security section. if your router was supplied by your internet provider, they will often have a copy of it, or can get it for you.
7/19/2013 1:56:48 PM •
Airlink...
Answered
on Jul 19, 2013
Airlink 658729082311 driver
Did you find a solution for this ?You haven't received any help because there was not enough information in your request for assistance.You might give Linux a try. I guarantee that it works better than Windows 98.
9/28/2012 8:19:18 PM •
Airlink...
Answered
on Sep 28, 2012
How secure my network
When you first setup your wireless router you should change the login password and then the wireless configuration, setup WAP or WAP2 encryption (WAP2 is the strongest encryption) and change the SSID and turn off SSID broadcast.
For further wireless protection enable MAC address filtering. The MAC address of the wireless card is entered in the router MAC address filter table, which allows only the wireless card with this MAC address to connect to the router.
Also if your router has a firewall then you should enable this feature.
The wireless card on the computer needs to be configured with the wireless router's settings. The LAN cable can be removed and the computer communicates wirelessly with the router.
All the computers on your network should have anti-virus program installed and firewall enabled.
9/21/2009 12:49:17 AM •
Airlink...
Answered
on Sep 21, 2009
Need my ket number for my AR325w wireless router
access the router home page usuall somthing along the kines
http://192.168.1.1
you will also need the admin password if it was set or the default password if it was not.
The default password is always in the manual.
Then once you are in you can go to the ireless settings page and copy the key setting from there
8/11/2009 9:24:59 PM •
Airlink...
Answered
on Aug 11, 2009
I forgot my userid and password
Do a factory reset, Some routers require the power to be plugged in OR
unplugged when doing
the reset. Try each way and hold the reset for a good 10 to 20 seconds.
then log on to the router with the default username and password
The default username and password may actually be admin for both.
8/6/2008 6:07:52 PM •
Airlink...
Answered
on Aug 06, 2008
Wireless connection problem
Hello There, are there any wireless computers that detects your router? If there is, most of the laptop computers has a built-in on/off (toggle) switch on the side to enable or disable the wireless card on your computer. Make sure it is "ON" then check if it will detect the wireless connection.
If it is a desktop, try to reboot the computer then check again. If none of the computers can detect your router, make sure that the wireless light on the router is lit up. You may also try changing the channel on the router.
8/3/2008 3:05:17 PM •
Airlink...
Answered
on Aug 03, 2008
Airlink router
Albert the unfortunate problem with cable modems is the equipment serial number. when your modem is deactivated by the company the serial number becomes locked in other words they view the modem as a loss and the only way to re-activate it is by a different user not your account. I know it is a stupid way of doing things but they think it will stop cable theft.. Goofy huh.. Anyway have a great day.. Be mucho blessed... mark
7/3/2008 2:02:49 PM •
Airlink...
Answered
on Jul 03, 2008
