20 Most Recent
1990 Yugo Cabrio Questions & Answers
The application failed to start
That 0x number is a base memory address in your computers memory. I would save all my data and reinstall the program since it looks like a corrupt program or registry entry is causing it to fail. It should not be a big deal.
I have a Yamaha r6
I use the same oil on my 2009 R6 and haven't had any problems, did you change the oil yourself, maybe has something to do with the shifter arm that was removed for oil filter access, that's where I'd start, that's all I could think of, my bike loves that stuff a noticeable change than regular oil, only thing is once you use it you can't use anythingelse(synthetic), good luck bud
Dear Sir/Madam, I`ve bought a
Yes, you need to put a Bosch pump, the original Lucas one is notoriously fragile: most of them have been replaced during warranty. Since it's the same engine as the one used in Peugeot Citroen you can get this one
http://www.dieseljones.co.uk/diesel-fuel-pumps/citroen-diesel-fuel-pumps-1/citroen-cx25-diesel-fuel-pumps/citroen-cx-25-d-turbo-2-bosch-diesel-fuel-pump-0460494998.html
Then you will need to install this kit
http://www.diesel-therm.com/vegetable-oil-kit.htm
It is very hard
Thanks for choosing FixYa and welcome to the site. You need to make sure you have the correct amount of tranmission fluid in the vehicle. If you do, you will probably need to take it to a shop and have it looked at. Sounds like there may be damage.
My car hesitates everytime i
If your car has a carburetter, the problem you describe would be caused by a faulty accelerator pump. There is a special pump built into the carb that sprays a spurt of fuel into the carb throat to prevent that flat spot when you accelerate quickly of change gears etc.
ELECTRIC WINDOW DOESNT WORK.
WITH KEY ON,HOLD WINDOW SWITCH IN DESIRED POSITION,THEN SLAM THE DOOR SHUT.THIS HAS WORKED FOR ME MANY TIMES.THEORY IS THAT WINDOW MOTOR BRUSHES LOST CONTACT . BY THE WAY.THIS TRICK ALSO WORKS ON OUTHER ELECTRICAL DEVICES SUCH AS FUEL PUMPS,STARTERS AND ALTERNATORS.THE CIRCUIT SHOUD BE ENERGIZED.WHILE JARING COMPONENT.DOESNT ALWAYS WORK AS OUTHER PROBLEMS MAY EXIST.IF IT DOES FIX THE PROBLEM PLAN ON A REPLACEMENT SOON.
Car tips
A broom is the quickest way to clean snow from a car. You can cut the
handle down on the broom and store it in the trunk.
Never warm your car in an attached garage and never with the garage door closed.
When tuning up your
car, set the gap on spark plugs using the widest gap that the
manufacturer recommends. Your car will run better, idle better, and
will give you better gas mileage.
