20 Most Recent
2005 Lotus Elise Questions & Answers
2005 Lotus Elise instrument cluster shorts in and out.
The "white plastic piece" you are referring to is probably a connector that mates with the cube shaped piece you mentioned.. If you remove the instrument panel and take it to an electronics supply store (Not Radio Shack) they might be able to help. Or go to a dealer.
What blower motor will fix in 05 lotus elise can
take the old one to a scrapyard and see what you can find ,if i can fit one from a citreon into a mitsubishi with the help of some some araldite and the fan blade from a opel astra .two self tappers and a couple of lucar connectors
Lotus elise heater fan has stopped working. What
it is poor design on behalf of lotus the resistor pack that controls the fan is mounted externally below the fan unit and subsequently gets wet corrodes and fails. it is a difficult job not for the faint hearted and requires **** shell removal. There is a lotus mod released to fix this fault i would suggest using it prevent future trouble. Speak to a lotus dealer or specialist.
