20 Most Recent
1999 Lotus Esprit Questions & Answers
Wheres the hood latch on a lotus esprit 99
US models such as my 1991 Lotus Esprit SE is to the left of the steering column at the bottom of the dash. Reach down and feel behind the dash there will be a rectangular pull or pivot which releases the hood.
I have a 1986 Lotus Turbo Esprit. Power cuts off
have to be quick ,got to get er indoors from work,or an earbashing .right back to car talk --not exactly sure what iam dealing with here ,carb or injection ,it has a distributor if its an 86 but does it have points or a module inside the distributor or just a pick up with the module under the coil ,Also this turbo ?? someone put new bearings in?? or the rotors as well .must dash i have 5 mins to go and get the old dragon
Looking for a lotus expert mechanic in nj
HI, sorry I am not closer, but the mechanics are very easy for any good mechanic, if you get a workshop manual from a UK Lotus specialist (sjsportscars). they do all parts mailorder the manual is very detailed, if you have a standard model, if you have the US high spec most race shops can tune the engine
Where is the trunk release on the Lotus Evora S?
it is in and or under the back seat. put it toward the middle of the car. if not you will brake it and the truck will not close. So you might want to go to the dealer to find out if there is a fix now to get the cable replaced so if you try to open it the wrong way at least you can close the trunk
Evora. Where is manual trunk (boot) release button?
There is a manual trunk release that is inside the car near the rear seats. You must make sure to pull the release towards the tunnel/middle of the car, not out away from it. Apparently, a number of sales people have tried to demonstrate it and by pulling on it incorrectly, broke the inner workings leaving the trunk then incapable of latching closed. The repair is not simple. Something about the cable being encased in a tube that is not straight but curved, so that when you pull on it the wrong way, it breaks something. Lotus is redesigning that component.
Also note you may need someone to gently lift on the trunk as you pull the lever. It should be a yellow lever.
