20 Most Recent 2004 Hyundai Santa Fe Questions & Answers
2answers
Error Code U0019 on a HYUNDAI SANTA FE MODEL YEAR 2004 ENGINE : DIESEL
Code meanning low speed can communication bus not sure what that is
3/13/2024 4:31:35 PM • 2004 Hyundai... • Answered on Mar 13, 2024
2004 Hyundai Santa Fe. Key fob only works if the ignition switch is in the On position. How to troubleshoot and fix.
The key fob does two things quite separately. It open and closes the doors. It also provides the correct security credentials to the vehicle immobilizer. At first is sounded like whomever programmed it only did half the job. It may also be that the internal battery is low. It is a complex error with the vehicle computer systems on a key fob with unknown history and issues. https://www.google.com/search?q=auto+electrician+near+me Or go into a place that does car alarms and radios. They will have the necessary test equipment and scan tool computers. ..
5/9/2023 7:19:08 PM • 2004 Hyundai... • Answered on May 09, 2023
2004 Santa Fe no acceleration after having to jumpstart and it doesn't give any codes
its in learn mode ,give it time if not that ,the check all fuses then scan it.. scan the OBD2 port.
3/17/2023 12:12:50 AM • 2004 Hyundai... • Answered on Mar 17, 2023
I got an 2004 Hyundai sanafa
SO JUST THE LAMP ACTS ODD OR YOU ACTUALY DID TESTS ON SAY SAND OR ICE TO PROVE IT IS DEAD; WE CAN GUESS WHAT YOU DID OR THINK. THE LAMP GLOWS WHEN ABS FAILS IF YOU SCANNED ABS THERE IS ERRORS IF ABS FAILS EVEN THE BRAKES, ACTUAL ARE BAD. NOW MY JEEP MY JEEP HAS TCS TO AND MY JEEP USERS GUIDE AND ME TESTING IT. ON SANDY LOT I CAN AT ANY TIME TURN THE STEERING ******* SAND MOVING EVEN SLOW AND TCS FLASHES. IT MEANS IT CAN'T CURE MY SKIDS, THE MANUAL IS CLEAR AS DAY ON THIS, IF YOU WERE TO READ IT. GLOVE BOX USERS GUIDE. TCS. CHAPTER TCS IS NOT MAGIC AND HAS REAL LIMITS. READ IT; OR ABS SCANS FAIL OR YOU SEE BRAKE PADS WORN CRACKER THIN OR CALIPERS STICKING.
1/18/2023 2:13:10 PM • 2004 Hyundai... • Answered on Jan 18, 2023
3answers
How do i remove dirve shaft bolts on a 2004 santa fe?
some bolts are tightened using a thread locking compound to make sure they wont loosen , do they look badly rusted< us a spray lube ,make sure you have the exact socket and it fits tightly, if its a hex bolt a six point or a 12 point or a torx head an make sure you have good tools that wont brake easy, and that you have leverage , if near gas tank heat or flames are not suggested good luck hope it helps you .Woody
6/2/2022 7:04:11 PM • 2004 Hyundai... • Answered on Jun 02, 2022
What Freon is need for 2004 Hyundai Santa Fe?
It's refrigerant r134a
8/11/2021 5:00:24 PM • 2004 Hyundai... • Answered on Aug 11, 2021
Hyundai Santa Fe 2004 Tracking device Installation. Where to find the constant power source and where to ground?
Hi..I bought 3 vehicles from JD byrider. They always install their GPS in the wiring harness behind the instrument panel. U can tap into any wires that feed directly to battery. (IE) clock, alarm, charger port that works when key is off..etc...
6/9/2021 2:22:33 PM • 2004 Hyundai... • Answered on Jun 09, 2021
Where is the engine number written of the 2004
Stamped on the left hand side of the engine block or it should be on your documents.
If this is to get correct parts, call the dealer as they should kep it on their database
5/20/2021 3:46:43 PM • 2004 Hyundai... • Answered on May 20, 2021
Qu'est-ce qu'un code u0009 et un code u0010 sur mon hyundai santa fe diesel ann?e 2004
https://www.youtube.com/watch?v=tURw8prJVIU J'esp?re que ?a aide. Merci pour l'opertunity pour aider. C. Walker
5/19/2020 12:44:13 PM • 2004 Hyundai... • Answered on May 19, 2020
2answers
How to hookup bluetooth in pioneer car stereo
you can try disconnection the power to the radio for 5 minutes (all the power not just the main power) then reconnect it and see it it reset.
12/1/2019 7:49:02 PM • 2004 Hyundai... • Answered on Dec 01, 2019
3answers
Indicater comes on but dosent
Without actually looking at the vehicle's electrical system (fuses, wiring, flasher unit, hazard switch, multi-function switch (LH side of steering wheel), etc., it's difficult to say.
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations and procedures, etc
10/7/2019 4:49:36 PM • 2004 Hyundai... • Answered on Oct 07, 2019
I need a picture of all fuses and fuse box diagram for 2004 hyundai santa fe
Hi First off what engine and drive line and exactly what are you looking to do or repair ? need more info
10/3/2019 12:58:15 AM • 2004 Hyundai... • Answered on Oct 03, 2019
My 2004 Santa Fe has had a slight power steering
Autozone...purchase a repair manual.
9/30/2019 6:11:12 PM • 2004 Hyundai... • Answered on Sep 30, 2019
After driving my 2004 Hyundai sata fe 2.4L for a 1/2 or so. It will not restart until it sits for 1/2 hour
purge valve or spark plug wires....replace purge valve first..
9/30/2019 6:09:27 PM • 2004 Hyundai... • Answered on Sep 30, 2019
My 2004 Hyundai Santa fe started slowing down on
change your spark plugs..all of them...and and put in the correct amount of oil..
9/30/2019 5:58:36 PM • 2004 Hyundai... • Answered on Sep 30, 2019
Where is the crankshaft sensor located on a 2004 hyundai santa fe ? What front tire do i need to remove in order to get to it ? Please help.....
if its the V6 2.7l its below the coil packs and behind cooling fan(must remove to replace it) on the side of the block, Drivers side... gonna need a flashlight and long extension...kinda hidden but its there follow the wire/connector back to the block....if its 4 cylinder its passenger side behind timing belt...must remove passenger wheel and timing belt cover..
9/30/2019 5:30:57 PM • 2004 Hyundai... • Answered on Sep 30, 2019
2004 Hyundai Santa Fe Logo
2,414 questions posted
Popular Products
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
View Most Popular
Santa Fe Hyundai
  • Santa Fe Hyundai
Most Popular Question
2004 hyundai santa fe starts but wants
  • Cars & Trucks
