20 Most Recent
2004 Kia Optima Questions & Answers
04kiaoptima 2.4crankshaft torque specs
main bearings torque is 18 ft lbs. plus 90 - 94 degrees, rod bearings torque is 13 - 16 ft lbs. plus 90 - 94 degrees.crankshaft damper bolt torque 80 - 94 ft lbs, fly wheel bolts torques 94 - 101 ft lbs.
How can I remove 120A alternator fuse?
120A fuses are usually bolted into the distribution center. I would look to see if you can push the wires connected to the fuse up and out of the box to access the bolts.
On kia rio how to change from farenheit to celsius
To shift from Fahrenheit to Celsius on Your KIA Rio, press the OFF button and the AUTO button together for at least four seconds. Now, the display will change from Fahrenheit to Celsius or the other way around.
Also, if you disconnect the battery and let it breathe for a while before reconnecting, the display will go to the original form, i.e., Centigrade or Celsius.
To know more about your KIA RIO, please refer to this owner's manual https://www.manualslib.com/manual/740114/Kia-Rio.html?page=195
Where is the OIL FILTER for the 2004 Kia Optima?
For the 2001 kia optima I have found the oil filter between the front passenger side tire and the engine. You can see it if you turn the wheels all the way to the left, although it helps if the filter cover is a bright color. To change it I had to remove the tire. I hope this helps.
Squealing noise
you have got something that is driven by the belt that is siezing up cos the bearings are worn out check all the driven items by feeling the pulleys if they are noisy/siezed to help decide where the problem is the belt tensioner or the guide rollers are favorite
2009 SEDONA, CRUISE CONTROL IN-OP. ESC LIGHT
There are two switches on the brake pedal, one for brake light, and one that kicks out the cruise when you hit the brake. That switch is closed when depressed (ie; brake pedal is up) and opens when pedal is pushed away from the switch, (unlike the brake light switch which closes when the pedal is pushed). This means it must be positioned and adjusted correctly for cruise to work.
Power door locks not working
Could be the door unlock relay is bad . Has a Separate relay for locking the doors . You'll have to look in your fuse boxes for location .
