20 Most Recent 2003 Land Rover Freelander Questions & Answers
Have an 03 freelander td4 with a clutch problem,
The problem is on your master and clutch slave cylinders. You said were dry and put clutch fluid. Wont do the proper job for clutch work as the inside rubber seals are not strong enough to make the pressure needed to release the clutch.
8/21/2021 12:29:08 PM • 2003 Land Rover... • Answered on Aug 21, 2021
3answers
2000 Freelander-window stuck in down after cable replace
Firstly check the wiring then motor is only working one way that means that the power is not being reversed to put it back up, switch the wires around from the switch if it go's back up then you know there is a wiring fault.
hope this helps
Regards
Dan
3/10/2019 8:51:28 AM • 2003 Land Rover... • Answered on Mar 10, 2019
4answers
Low Fuel Pressure on Landrover Freelander TD4
From 53 reg onwards, diesel pump is under R.H. rear wheel arch, hidden by the plastic wheel arch liner. Older versions have combined fuel pump/sender in the tank (under R.H part of rear seat).
You should be able to hear a faint purr from the pump when ignition is turned on but engine not yet running.
12/23/2018 8:17:00 AM • 2003 Land Rover... • Answered on Dec 23, 2018
Blows out black smoke from exhaust & engine when going up hills and smells of burning
It is burning oil. The most likely one or more piston rings are worn out. Consult a tech, on what to do next, like repair the motor or replace it.
2/20/2018 2:27:48 PM • 2003 Land Rover... • Answered on Feb 20, 2018
Amplifier location in 2003 freelander
Start with a phone call to a Freelander dealer, somewhere. As far as I know, factory original cars/trucks have the amplifier built in to the radio head, including Land Rovers. Ask their "parts department" this same question. They will know if there is a separate amplifier. If there is, by chance, I sould suppose it to be inside the dashboard in the vicinity of the radio head. God bless your efforts.
2/19/2018 8:35:53 PM • 2003 Land Rover... • Answered on Feb 19, 2018
Freelander won't start
run the fault codes
12/24/2017 12:14:46 AM • 2003 Land Rover... • Answered on Dec 24, 2017
Black smoke and loss of power from 2003 landrover
hi david. see if this link helps you find out what is wrong. Black smoke and loss of power from 2003 landrover freelander Google Search
11/17/2017 2:43:01 PM • 2003 Land Rover... • Answered on Nov 17, 2017
Landrover Freelander V6 engine code 25K, Need
i want to know the timing marks for my 2003 land rover freelander
10/24/2017 5:36:32 PM • 2003 Land Rover... • Answered on Oct 24, 2017
I parked my car in
Starter not grounded to car,most starters,ground through body of starter,or bad conection on positive wire or solenoid wire,without complete circut on dc,will not work
10/24/2017 10:59:25 AM • 2003 Land Rover... • Answered on Oct 24, 2017
2answers
No low beam lights but have high beam lights
check the light globe as a lot of cars have two filaments in the halogen globe. One for low beam and one high beam filament. You could get a 12v probe and then pull of the light plug and see if low beam bul is getting 12 volts when lights on low beam.
10/12/2017 12:46:34 PM • 2003 Land Rover... • Answered on Oct 12, 2017
2answers
I have a freelander td4
belts do fail and if a second belt was damaged by the first failure , it would make sense to replace both belts at the same time better now that again in the near future when it will most likely be at the most inconvenient time you could imagine
9/8/2017 10:06:17 PM • 2003 Land Rover... • Answered on Sep 08, 2017
When the heater is on in my 2003 Freelander, I get a film on my windshield and front windows. There is no smell of coolant and the heater core is not leaking. Any suggestions? Running defrost doesn
I believe the film on your window is coolant vapor. To test this go to autozone or similar and get a coolant leak detection kit. The kit contains a UV flashlight a pair of glasses and a dye you add to the radiator. Add the dye to radiator, drive vehicle normally but run heater, let film condensation on Windows. Wait until dark and put on the glasses. Shine light on the Windows that have film if the window glows then the film is antifreeze vapor and not safe to breathe.
6/24/2017 11:34:00 PM • 2003 Land Rover... • Answered on Jun 24, 2017
Freelander td4 2005... changed fuel
did you install new filter in the right direction??? filters have a "flow arrow" pointing to which way it goes arrow points to the engine... also did a lot of junk come out of old filter or the fuel line if so dirt is now blocking fuel rails... dirt will now pass through injectors ...
5/16/2017 12:18:55 PM • 2003 Land Rover... • Answered on May 16, 2017
2004 Freelander Coolant Leak
Check for bubbling in the reservoir tank. It is possible that there is a head gasket leak. Look for steam coming from the exhaust pipe? Steam coming out from reservoir cap vent! images-i2kfvbehogcfl53l2fxxborc-4-0.jpg f21-15-i2kfvbehogcfl53l2fxxborc-4-2.gif
3/17/2017 2:43:12 AM • 2003 Land Rover... • Answered on Mar 17, 2017
2003 Land Rover Freelander Logo
624 questions posted
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
View Most Popular
Freelander Land Rover
  • Freelander Land Rover
Most Popular Question
rear window not hang over key switch in
  • Cars & Trucks
