20 Most Recent
2001 Hyundai Accent Questions & Answers
I have a 2001 Hyundai accent with the 1.5 l single overhead cam I need the torque number and sequence for The rocker shafts
The torque specification for the rocker shafts on the 2001 Hyundai Accent with the 1.5L single overhead cam engine is 18-20 lb-ft. The proper torque sequence is as follows:
- Tighten the bolts to 8 lb-ft in a crosswise pattern.
- Increase the torque to 15 lb-ft, again in a crosswise pattern.
- Finally, tighten the bolts to the full torque of 18-20 lb-ft, again in a crosswise pattern.
Make sure to use a torque wrench and follow the sequence carefully to ensure proper tightening and prevent damage.
Where is the MAP sensor?
Learn how to use YouTube. Go to the YouTube web site, and in the search box at the top of the screen type "2001 hyundai accent map sensor". Look at the videos it brings up -- it may not show exactly a 2001 Accent, but you should be able to find an engine that looks like yours and see where the MAP Sensor is.
Overdrive sensor
NO, just replace the Vehicle Speed Sensor, it is on the transmission.
Break light switch installation
Look on the bar the brake pedal is attached to, you will see a switch at or near the top, go to the dealer with your VIN# and buy a new one, first make sure the issue is not the fuse or the bulbs/wiring, don't throw parts at it, it will get very expensive fast, do the electrical test/checks first.
My 2001 hyundai accent has
i think you need to go back to basics.if here is no obd fault codes in the system to give you a clue. then use a multimeter and have a good look at the wiring for corroded connectors etc. including the fuel pump?
