20 Most Recent 2002 Land Rover Freelander Questions & Answers
How to reset timing marks after replacing a broken timing belt?
Land Rover Freelander 2002-2005 KV6 Timming belt and ...
? 4:31 https://www.youtube.com/watch?v=sz_oe9tIFH4 Jul 3, 2011 - Uploaded by Jaime Depaula Land Rover Freelander 2002-2005 KV6 Timming belt andreplacing valves - Video 2 ... shops in North Eastern USA for bent valves and timing belt change? .... Land Rover 200tdiTiming Belt -From Broken Belt to Retiming the ...
ROVER K Series Cambelt Change Video - YouTube
? 10:52 https://www.youtube.com/watch?v=1Qn8ljQKZxA May 4, 2012 - Uploaded by metalworker007 How to change a rover K series cam belt .. by Technozen of ...soy espa?ol porfavor quiero saber timing marks de MG ROVER 25 petrol 1795cc engen .... Hi, Have a Land Rover Freelander1999 petrol serie K, that dont start, ...
Freelander 1.8i timing belt - Land Rover Technical Archive - LR4x4 ...
forums.lr4x4.com > ... > Tech Archive > Land Rover Technical Archive
Nov 20, 2006 - 1 post - ‎1 author The following is instructions for replacing the timing (or camshaft) belt on the 1.8i petrol engine, as fitted to a Freelander. This is the K-series ... With the timing set, thecam sprocket marks should look like this. Posted Image
How to Replace timing belt on Land Rover Freelander 2.5 ...
2/24/2022 10:52:57 PM • 2002 Land Rover... • Answered on Feb 24, 2022
3answers
Gettting the intake plenum off a 02 freelander
My 2002 Land Rover Freelander V6 thermostat crapped out as well and I decided to replace it myself. The plenum is deceptive, but after 3 hours of looking and trying I finally got it off. Of course there are many hoses and electrical connections that need to be removed, but that's the easy part because you can see them all. The bolts that hold on the plenum are what your worried about and I will now tell you where they are. Read this and you should take about 30min to remove the plenum. There are a total of 6 bolts to be removed that secure the intake plenum to the intake manifolds. First remove the 4, 10mm large and obvious bolts at the top of the plenum. Now here is the tricky part, there are 2 bolts that are at the back of the plenum near the fire wall. As you are looking at the intake plenum from the front of the car, they are on the back side of the plenum near the fire wall on the passenger and driver side of the intake plenum. Both bolts your looking for are 8mm bolts. If you remove a 10mm bolt, your removing the bolts that secure the rear spark plug coils. The driver side rear intake plenum 8mm bolt is secured to the plenum itself. Fell with your hand about the back of the plenum on the right side for a lone bolt that is in the plenum with a metal tab that goes down to the back of the rear cylinder head. Remove the bolt that is attached to the intake plenum, not on the rear cylinder head The passenger side one is a bit different. Feel on the back of the intake plenum about the passenger side for a metal support tab that comes down from the intake plenum and secures to the rear cylinder head. Where the support tab attaches to the head is a 8mm bolt that you remove. Now here come the leap of faith. If you have the 4, 10mm obvious bolts removed and the 2, 8mm from the rear of the plenum removed, and if you can rock the plenum up and down about 2-3 inches,but it still feels like its attached to the intake manifolds in the middle of the engine, then you have removed all the bolts that secure the intake plenum to the engine. This is good. The intake plenum is now being held on by the rear intake manifold by 3 O-ring gaskets. Push onto the back of the intake plenum near the firewall to expose a gap at the front of the intake plenum at the front intake manifold. Put 2-3 long flat screwdrivers into the gap or a small pry bar, and ever so gently but forcefully, apply prying force as to not damage the mating surface of the aluminum intake manifold, until the intake plenum pops off. It will just POP off. Now that the intake plenum is popped off, take careful note of all the electrical plugs and hoses as to where they attach. You will not need any tools to disconnect the electrical plugs or hoses. To remove the hoses, push down the red ring with you fingers that the hose goes into and pull on the hose, it should come out very easily. The electrical connectors, push on the metal clip down and pull the connector loose. The electrical connectors only plug into their own plug, so you cant mess them up. Tools you will need to replace the thermostat; 1. 8mm combo wrench. Make sure its not too long, shorter is better. 2. 10mm socket, shallow. 10mm combo wrench 3. 2-3 flat screwdrivers, for prying off the intake plenum 4. Ratchet wrench 5. 1 foot long worth of socket extensions. 2 6inch extensions will work as well 6. Universal socket joint 7. Angled needle nose pliers make it easier for hose clap removal, but straight needle nose pliers will work 8. Diagonal cutters to cut securing zip ties for the wiring harness Take you time, once the plenum is off it goes pretty smooth after that. We removed just the forward intake manifold and that was more than enough clearance to remove the thermostat. You do not need to remove the fuel rail or spark plug coils from the manifold but you will need to disconnect the electrical connections to move the intake manifold out of the way. Take pictures, there's a lot of hoses that go all over the place. The electrical connectors are only long enough to go where their supposed to go. Then take that UK piece of **** to the dealer and trade it in for anything made in the USA or Japan. Changing a thermostat in any of those will only take 10 min and require 1 tool. Repair provided by KPCYCLES.com of Honolulu, HI
1/21/2021 2:50:31 PM • 2002 Land Rover... • Answered on Jan 21, 2021
2answers
Freelander 1.8.window down cable snapped.Up cable
complete new unit only solution
3/10/2019 8:57:14 AM • 2002 Land Rover... • Answered on Mar 10, 2019
2answers
Cables on the electric windows keep breaking . Can
try using electrical tape to proect them from the weather
3/10/2019 8:55:46 AM • 2002 Land Rover... • Answered on Mar 10, 2019
3answers
Cant open tailgate window won.t come down
This video should solve it. If the window is not dropping enough see the video at about time 4:10 where a problem causing this can be seen followed by a solution. https://youtu.be/xLQOzLaq5mw
3/10/2019 8:47:39 AM • 2002 Land Rover... • Answered on Mar 10, 2019
2002,land rover, freelander, over heating and the
Have a compression test done and make sure the head gasket is OK before doing anything else.
12/18/2018 6:07:17 PM • 2002 Land Rover... • Answered on Dec 18, 2018
2answers
T reg freelander cooling fan does not cut in
Replace sensor
10/21/2018 7:57:03 AM • 2002 Land Rover... • Answered on Oct 21, 2018
UPPER AND LOWER SUSPENSION BALL-JOINT
Need reliable Land Rover Freelander parts? ... The Land Rover Freelander was introduced to the market as a premium ... Land Rover Replacement Antenna ... www.carpartswholesale.com/cpw/land_rover~freelander~parts.html www.carpartswholesale.com/cpw/land_rover~freelander~parts.htmlI have just gone into this site. They seem to have everything you could possibley need for yr Land rover - hope your are successful
9/30/2018 5:45:15 AM • 2002 Land Rover... • Answered on Sep 30, 2018
How long can I use
They are made to last for years. You don't replace them until they start to leak.
9/30/2018 5:45:00 AM • 2002 Land Rover... • Answered on Sep 30, 2018
2answers
Gas cap on 2002 Land Rover Freelander damaged.
it comes apart from the bottom
9/30/2018 5:44:34 AM • 2002 Land Rover... • Answered on Sep 30, 2018
3answers
Cooling system freelander 2001
what would a recon engine cost for a freelander 1800 2001
9/30/2018 5:44:14 AM • 2002 Land Rover... • Answered on Sep 30, 2018
2answers
98 landrover freelander
Try the rover dealer.
9/30/2018 5:43:59 AM • 2002 Land Rover... • Answered on Sep 30, 2018
2answers
I have a 2002 Land Rover Freelander that is stuck in Park. The stop light switch has been replaced with an autozone part, but it still does not work. The break lights are also not working.
This might help you. Otherwise, just find a mechanic you trust and have him or her check the brake light bulbs. It could also be fuse problems. Check the diagram for your lights or check your manual. http://forums.edmunds.com/discussion/5166/land-rover/freelander/freelander-transmission-problems For your fuse box diagram: http://carwiringdiagram.net/2002-land-rover-freelander-fuse-box-diagram/
9/30/2018 5:40:39 AM • 2002 Land Rover... • Answered on Sep 30, 2018
2answers
My 02 Land Rover Freelander shakes when I accelerate. It is definately coming from the front.
Check the universal joint, or the CV-joint, if this is OK, check for wheel balance
9/30/2018 5:40:21 AM • 2002 Land Rover... • Answered on Sep 30, 2018
2answers
02 freelander noisy vibration when fan switched on
fan is hitting casing?
9/30/2018 5:39:30 AM • 2002 Land Rover... • Answered on Sep 30, 2018
2answers
2002 Land Rover Freelander radiator and air fan not working
there is a module mounted on the fan shroud that is a common problem. but as always, check fuses, connectors and grounds!
9/30/2018 5:34:55 AM • 2002 Land Rover... • Answered on Sep 30, 2018
3answers
Land Rover Freelander heater/fan switch not working
u need a Freelander Blower Fan Speed Repair Kit
go on e-bay Item number: 160320517862
9/30/2018 5:34:35 AM • 2002 Land Rover... • Answered on Sep 30, 2018
2002 Land Rover Freelander Logo
1,319 questions posted
Top Land Rover Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Land Rover Expert? Answer questions, earn points and help others
View Most Popular
Freelander Land Rover
  • Freelander Land Rover
Most Popular Question
2002 land rover freelander sometimes
  • Cars & Trucks
