20 Most Recent
2000 Mercury Sable Questions & Answers
2000 Sable change keyless entry code
The procedure for changing the code is covered in the owners manual. You will need the current code. If you don't have the manual I can document the specifics.
3.0l. Why is fuel pump noisy?
It could be that your fuel filter is partially plugged. You'll find the filter under the right rear plastic inner fender.
I have a 2000 mercury sable dohc 3.0 and the
Does it leak while driving or setting? If setting then let it set and when it leaks , find the source. Best to have a lift.
Run it on the lift to see where the leak is if driving. Make sure it is not a line or the breather tube on top.
2000 ford mercury sable ls i own this car and
if is a slow leak and you don't hear a load hissing is ok! replace any hose that you think needs replacement, on top of that check your radiator hoses for swelling ,if the car is leaking water each time you drive the car your risking the engine to blow a head gasket so I would fix the problem right away....
Keyless entry door pad
Entry Code
The system (permanent) entry code is located in three places:
- on the owner's wallet code card (in glove compartment)
- electronically accessible by requesting the remote anti-theft personality module KEYCODE PID on the New Generation Star (NGS) Tester 007-00500 or equivalent.
- on the remote anti-theft personality module housing
The remote anti-theft personality module is programmed at the factory with a five-digit entry code. A replacement remote anti-theft personality module includes replacement labels and a new owner's code card.
Remote Anti-theft Personality (RAP) Module
C253
Above the drivers side footwell, directly above the accelerator pedal
2000 sable wont go into gear
No quick fix. If you are lucky, it is just the flexplate snapped loose from the torque converter. There is usually a door that you take off to access the 4 bolts that hold the flex plate to the converter. Remove that door to see if the bolts have sheared off.
Electrical Issues
All the components you mentioned have control modules that you have likely burned out from the reverse hook up of the battery.
