20 Most Recent
1993 Subaru Legacy Questions & Answers
Can not get in the trunk. The handle is broken.
Legacy, right? Can you tilt the backseats' backrests forward? like when you want to transport something big in the trunk... I suppose the sedan has this similarly to the station wagon.
Use a pocket torch to look for the lock body from inside and there should be a small button or better a lever that you have no clue what it is there for, right? try to push it or pull it from ech side untill it opens.
It is actually there to prevent transporting people in the trunk against their will(unlike the movies, where it is possible).
Feel free to send any feedback
If helpful, please rate
93 Legacy air suspension how to
this link is for the factory service manual for the older legacy that you have. section 4 has the air suspension shown. i don't see anything in there about servicing the unit.
I think you are out of luck for getting the original air suspension repaired. parts to convert to aftermarket air ride or regular strut/spring suspension will set you back considerable funds either way. the labor should be around 4 hours
https://drive.google.com/open?id=0B4H_Uz2vUjAwTUUtaUU5WXFNc1k
1993 Subaru Legacy door locks
If it's mega cold in your area, it could be ice. We've had several things not open lately. All due to moisture/condensation freezing.
Just a tho't.
Subaru Gearbox problem
there might be more than one issue here. its common for the early auto transmissions to not have the extra shims added to the center differential. This causes binding for the front axles and can damage a few parts. There was a recall for this many years ago. The other possibility is the valve body is manufunctioning and not fully engaging the gear your selecting. The fix is to get the valve body overhauled/rebuilt or replaced
