20 Most Recent
1995 Subaru Legacy Questions & Answers
What fuse is for the rear fog lights.
please first check for the corresponding fuse in the manual. If you can find it in your car manual or you need the manual, please cell Subaru directly at 1-800-782-2783. Thank you.
My daughter's 1995 SL2 died
Does this happen when the gas level is low? What can happen is that the gas evaporative system is not working properly, and the gas tank gets a partial vacuum which the fuel pump cannot overcome. If you hear a shhhhhh sound when the gas cap is opened, that's what is is. Could also be dirt in the gas tank, Most tanks can be drained via a small plug in the bottom. Removing the fuel pump to inspect the attached filter is a possible if fiddly job.
1995 subaru no fuel pressure
The fuel pump will only run for a few seconds ,untill the engine starts.And yes i think the relay is the problem ,check a manual to find its location . Or if it was me i would join the Subru forum free to join then ask on the forum .
My 1995 subaru legacy lsi
code p 0441 refers to evaporative emission (EVAP) system --incorrect flow detected ==== causes --- hose connection/s--- intake leak---EVAP canister purge valve replace the purge valve
Problem with heater core in a 2001 Subaru Legacy
If you smell antifreeze then the core may be leaking. Burning oil may be rocker covers leaking on the exhaust and the odor being drawn in by the fan. In any case replacing the clutch wouldn't necessarily cause the problem.
How to fix the torque bar located in the trunk lid
You need to position the spring with the bushing on it against the hinge and set
it into the slot just under the panel behind your backglass. On the opposite
side, pull the end into say the middle hole for starters and make sure it is
seated completely. Do the same for the other side, open the trunk and make sure
it stays open, if not you can adjust it by moving your torsion springs to the
next hole.
