20 Most Recent 1998 Honda Accord Questions & Answers
2answers
Diagram to remove a automatic transmission in a
I have the directions to remove/install transmission, need email address to send to
7/14/2022 8:32:59 AM • 1998 Honda... • Answered on Jul 14, 2022
3answers
1998 Honda Accord EX V6 driver side turn signal.
Start your car, turn the wheel all the way to the right, then take out the retaining clip on the inside of the fender well. the reach inside and rotate the bulb counterclockwise and pull it out
6/26/2022 8:05:34 PM • 1998 Honda... • Answered on Jun 26, 2022
2answers
A need code for radio honda accor 1998 ex v6
only dealer can get you the code and you have to prove you are the owner of the car.
6/26/2022 8:02:39 PM • 1998 Honda... • Answered on Jun 26, 2022
4answers
Power door locks not working on 1998 honda accord lx
I promise this works 'cause I used it:
Put the key in the ignition, move the intermittent wiper control to the middle possition and then turn the key on.
just to clarify it's the ring that controlls the intermittent wiper speed and not the int / low/ high switch.
What this does is it resets the multiplex unit that controlls the accessories such as the power door locks. This problem usually happens once the battery has been removed or disconnected and reconnected. Every once in a while the multiplex systems lock up. Especially on the 98s. That's how you wake em up.
4/24/2021 5:10:48 AM • 1998 Honda... • Answered on Apr 24, 2021
Need heating fixed in 98 Honda accord no lights coming on climate control box
These vehicles are notorious for bad climate control modules. There are several companies that will check and rebuild in nessicary.
4/24/2019 6:13:39 PM • 1998 Honda... • Answered on Apr 24, 2019
Multiple misfire, rough idle, dies
Sounds like it did not go back together right.
3/10/2019 2:41:30 AM • 1998 Honda... • Answered on Mar 10, 2019
3answers
Have a 1998 Honda accord automatic transmission want go into reverse but all other gears are fine. It does make a popping sound when put into park. What could be the problem
There's a website reliable-store all heavy equipment repair issues servicing, loading, wiring, engine problems everything is covered here its a must try for those who aren't fully equipped with tools or knowledge
2/14/2019 2:12:33 AM • 1998 Honda... • Answered on Feb 14, 2019
2answers
Accidentally reversed the battery cables on my 98
If your car came with the Prestige Alarm unit, there is a possibility that the alarm box got deprogrammed or burned, and left the anti-theft activated. Use the Valet Switch to deactivate the alarm permanently, and see if the car starts. For some reason unknown to me, it takes a couple of cycles of crank/ take the ignition switch off, crank again for the Valet Switch to work. In my 98 Accord, this micro-switch is installed in the left front kicker panel, but there is no guarantee that it will be in the same place in you accord, since it is a dealer installed option
3/15/2018 11:07:57 AM • 1998 Honda... • Answered on Mar 15, 2018
2answers
98 Honda Accord Wont Start
either have a shop scan it for trouble codes or buy a scanner your self at local parts store have OBDII scanner and find out for your self it could be a number of things.
3/15/2018 11:05:33 AM • 1998 Honda... • Answered on Mar 15, 2018
Took 2002 Honda Accord EX - V6 in to dealer for oil change. They are telling me I have a transmission leak and need to replace the torque converter seal and rear main seal $1300. I told him I did not
If you have a leak of any kind, it will be on your carport or garage floor. If it is engine rear seal it will be oil, if it is Trans then it will be reddish fluid. Unfortunately this practice of up selling is getting more common. If you are really concerned take it to another reliable mechanic for second opinion. If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
2/13/2018 12:02:42 AM • 1998 Honda... • Answered on Feb 13, 2018
2answers
1998 V6 honda accord when running rpms keep surging
Mechanical issue with the idle speed control system, most likely sludged up.
2/6/2018 11:32:01 PM • 1998 Honda... • Answered on Feb 06, 2018
2answers
2001 Accord - Cruise control light and clock light do not come on
At very cheap rates you can go for manuals from this store. Just check Honda Accord Service Manual 2001
2/5/2018 9:42:57 AM • 1998 Honda... • Answered on Feb 05, 2018
I have a 98 Honda Accord v6 3.0. I just cleaned the egr valve and passages, changed distributor cap and rotor, valve cover gaskets, spark plugs and o2 sensor and now i am getting a p1399, 133, 303, an
Hello Corey Wilkey, I got one thing that your OXYGEN SENSORS always get blamed for... (sorry). As a matter of FACT... your whole list is where the money gets spent first... (not so cheap: save all those good parts). Sadly (I believe) all your troubles will resolve to a BLOCKED EXHAUST... started on occasion but has popped and now might run... but definitely stops (muffler/resonator). or... Onset was pretty quick... now really does not even threaten to run anymore (catalytic convertor) If you don't mind a filthy job two people & good shop hoist... it is not a horrible job... but if you are taking to an Exhaust shop... Know your material PRICES ( and STATE laws ) BEFORE you go...!! The muffler shop can TEST & CONFIRM... Muffler & resonator Prices 1998 HONDA ACCORD 3 0L V6 Muffler Resonator RockAuto Catalytic Convertor Prices (various: any State) 1998 HONDA ACCORD 3 0L V6 Catalytic Converter RockAuto Specific detail CATALYTIC Conv. (C.A.R.B. Compliant) More Information for DAVICO 169796 Hope this helps Carnac the Magnificent
1/8/2018 10:36:45 PM • 1998 Honda... • Answered on Jan 08, 2018
My '98 Honda Accord shuts down totally while
  • Sound a little like block exhaust or exhaust system starting to fail. If not this, the spark plugs are suspected. Have an old set of plugs around that you can replace to find out. Good luck.
1/3/2018 3:38:31 PM • 1998 Honda... • Answered on Jan 03, 2018
Horn not working after car alarm went off
Test for power and ground going to the horn. If it's getting power and ground, the horn is bad from running for so long
12/30/2017 12:41:53 AM • 1998 Honda... • Answered on Dec 30, 2017
Cruse control not working 1898 Honda Accord EX
I have read your problem and you can easily get the solution of your problem from the given link http://toolsnyou.com/ .
12/26/2017 5:51:01 AM • 1998 Honda... • Answered on Dec 26, 2017
1998 Honda Accord Logo
2,296 questions posted
Popular Products
1992 Honda Accord
1992 Honda Accord
2,998 Questions
1991 Honda Accord
1991 Honda Accord
2,681 Questions
1995 Honda Accord
1995 Honda Accord
1,631 Questions
1996 Honda Accord
1996 Honda Accord
1,636 Questions
1994 Honda Accord
1994 Honda Accord
1,470 Questions
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
View Most Popular
Accord Honda
  • Accord Honda
Most Popular Question
power door locks not working 1998 honda
  • Cars & Trucks
