20 Most Recent
2004 Suzuki Verona Questions & Answers
My turn signal and widows don't work check fuse and wires
Look under the steering wheel fuse box and check the isu fuse the isu fuse under the dash it is the main fuse for box and the electrical fuses in it if it don't work none will properly if at even if you switch them. You'll know if a fuse is blown if the metal link in the fuse is broken
2004 Suzuki Verona 2.5 liter, 6 cylinder. Looking for the idle air control (IAC) valve location please.
The 2004 Suzuki Verona 2.5L does not utilize an idle air control (IAC) valve. Instead, an electronic throttle control (ETC) system is used which Suzuki calls the "main throttle idle actuator" (MTIA). This component is the throttle body assembly but with an internal motor that adjusts the throttle plate open or closed based on accelerator pedal position inputs to the engine control module (ECM). Similarly, the ECM adjusts the throttle plate angle at idle to control idle speed. If the idle speed is not correct, the throttle body may need to be cleaned, calibrated or replaced. You can read more here: https://www.yourmechanic.com/article/how-to-replace-a-throttle-controller-by-mia-bevacqua
How to replace fuel pump on Suzuki Verona 2004
Fixya website has never answered a single question I have ever asked. This site is so f****ing ignorant! One simple question and 4 "answers" that literally have nothing to do with the question. Hell, the last answer just says "try (and a bunch of random sets of 4 digit numbers)". WTF is that dip sh*t?
2004 suzuki verona hold button
The hold button on my 2004 Suzuki Verona comes on out of no where flashing and it stops my car from excelerating. I haveto pull over and shut the car off then on in order to contiue driving. After 2k dollars in reapirs over the last 3 months...I just want to know if this feature can be disconnected???? I don't need it. Thanks
I need to replace my
These parts are generally used on more than one vehicle. Since the Verona is a Japanese car, I would try looking at similar Japense models for something similar. Another thought is the junk yards, some of these must have made their way there by now.
Doug
P0133, P0420 and P0430
i went
code p 0133 refers to heated oxygen sensor (HO2S) 1 bank 1---slow response ===causes ---heating inoperative --- wiring ---HO2S
also refers to oxygen sensor (O2S) 1 bank 1--slow response ===causes ---wiring ---O2S
also refers toHO2S 1 bank 1--no signal====causes wiring ---HO2S
the HO2S is the sensor in the exhaust manifold before the cat converter and reads the exhaust gas composition to report to the ECM to adjust air fuel mixture
For this code the HO2S needs replacing
the reference to an O2 S is the sensor after the cat converter and reports on the cat performance
code p0420 refers to catalytic converter bank 1-- efficiency below threshold ==== causes cat converter ---wiring ---HO2S
code p 0430 refers to the same as p 0420 but cat converter bank 2 causes the same including the HO2S
I would first get both HO2S sensors ( bank 1 and bank 2) replaced then have the fault codes read
if the cat converters are sill showing as the 420-430 codes then muffler shops have cheaper cats that what you were quoted
