20 Most Recent 1996 Jeep Grand Cherokee Questions & Answers
4answers
96 jeep grand cherokee not starting. starter is not engaging the flywheel
Bad bendix, replace starter soon or may damage flywheel
2/15/2023 9:04:44 PM • 1996 Jeep Grand... • Answered on Feb 15, 2023
Nesecito un diafragma de como conectar los cables
this is USA English site. please post in english.
1/11/2023 5:41:06 AM • 1996 Jeep Grand... • Answered on Jan 11, 2023
Hooking up pioneer radio to a 96 grand jeep cherokee diagram
they sell adapters so cutting up oem Harnesses need not be down the diagram is in the service manual on all cars. https://www.scosche.com/car-audio/installation/harness
11/26/2022 2:51:44 PM • 1996 Jeep Grand... • Answered on Nov 26, 2022
Need a diagram for 1996 jeep cherokee sport fuses
Go to the cherokeeforum.com, (cherokee-forum-dot-com)... Join the forum. You'll be surprised just how many other Jeep XJ owners are there to help... I joined that forum the 1st week after i bought my 1993 Jeep XJ..... They' always give ya a straight answer & can usually give step-by-steps on how to fix a problem, all ya gotta do is ask...
10/27/2022 10:04:10 PM • 1996 Jeep Grand... • Answered on Oct 27, 2022
3answers
Fireing order diagram
1-5-3-6-2-4 Clockwise alt="Cables order">
10/3/2022 8:09:13 AM • 1996 Jeep Grand... • Answered on Oct 03, 2022
Hi I have a 1996 Jeep Grand Cherokee. The muffler fell off. and looks like wires are hanging. The Jeep won't start.
Question edited for clarity and add some full stops and commas and stuff. That was one of the longest run-on sentences! Question moved to model category. Yes, the wires are probably from the o2 sensors on the Catalytic Converter but really could be from anything. Reconnecting them should fix the starting issue.
8/2/2022 6:50:54 PM • 1996 Jeep Grand... • Answered on Aug 02, 2022
3answers
1996 Jeep Cherokee 4.0 MPI.
Lets start with technical bulletin how to determine whether fuel pressure regulator is at fault or not :-
FUEL PUMP PRESSURE TEST - ALL ENGINES WITH PRESSURE TEST PORT
Use this test in conjunction with the Fuel Pump Capacity Test, Fuel Pressure Leak Down Test and Fuel Pump Amperage Test found elsewhere in this group.
Check Valve Operation: The electric fuel pump outlet contains a one-way check valve to prevent fuel flow back into the tank and to maintain fuel supply line pressure (engine warm) when pump is not operational. It is also used to keep the fuel supply line full of gasoline when pump is not operational. After the vehicle has cooled down, fuel pressure may drop to 0 psi (cold fluid contracts), but liquid gasoline will remain in fuel supply line between the check valve and fuel injectors. Fuel pressure that has dropped to 0 psi on a cooled down vehicle (engine off) is a normal condition. When the electric fuel pump is activated, fuel pressure should immediately (1 - 2 seconds) rise to specification.
All fuel systems are equipped with a fuel tank module mounted, combination fuel filter/fuel pressure regulator. The fuel pressure regulator is not controlled by engine vacuum.
WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. BEFORE DISCONNECTING FUEL LINE AT FUEL RAIL, THIS PRESSURE MUST BE RELEASED. REFER TO THE FUEL SYSTEM PRESSURE RELEASE PROCEDURE.
1. Remove protective cap at fuel rail test port. Connect the 0 - 414 kPa (0-60 psi) fuel pressure gauge (from gauge set 5069) to test port pressure fitting on fuel rail
2. Start and warm engine and note pressure gauge reading. Fuel pressure should be 339 kPa ± 34 kPa (49.2 psi ± 5 psi) at idle.
3. If engine runs, but pressure is below 44.2 psi, check for a kinked fuel supply line somewhere between fuel rail and fuel pump module. If line is not kinked, but specifications for either the Fuel Pump Capacity, Fuel Pump Amperage or Fuel Pressure Leak Down Tests were not met, replace fuel pump module assembly.
4. If operating pressure is above 54.2 psi, electric fuel pump is OK, but fuel pressure regulator is defective. Replace fuel filter/fuel pressure regulator. .
5. Install protective cap to fuel rail test port.
Now,
The fuel pressure regulator is part of the fuel pump, it is in the fuel tank.
On this vehicle the regulator is part of the pump and not serviceable separately so if the regulator is bad the whole pump assembly will need to be replaced.
Good Luck!!
Thanks!!
5/7/2022 5:57:06 AM • 1996 Jeep Grand... • Answered on May 07, 2022
1994 Jeep Grand Cherokee. My car is turning over but won't start?
An engine needs 3 things to run. Fuel, Air and spark. You've checked the spark so move onto the air and fuel system. I'm assuming you did a full service on the replacement engine after you fitted it? Even a dirty Air filter can cause bigger issue that you would expect. Have you checked to see if the engine is getting Fuel? If it is just turning over and not trying it might not be getting fuel to the cylinders. When you checked the plugs for a spark were they wet and smell of fuel when you first took them out? Have you had the vehicle scanned with an OBD2 scanner for trouble codes? These can give clues to what and where the problem might be. If you have to pay for the scan get prices at 4 or 5 different places as prices can be VERY different.
3/19/2022 2:01:57 PM • 1996 Jeep Grand... • Answered on Mar 19, 2022
How to replace the distributor
TO REPLACE A DISTRIBUTOR FIRST YOU HAVE TO GET ENGINE IN NUMBER 1 FIRING POSITION IN COMPRESSION STROKE.WITH ROTOR POINTING TO NUMBER 1 POSITION ON DISTRIBUTOR CAP BESURE TO PUT NUMBER ALL PLUGS WIRES AND NUMBER ON DISTRIBUTOR SO YOU WONT GET CONFUSE AND MARK THE DISTRIBUTOR BASE ALSO SO YOU CAN PUT IT BACK IN THE ORIGINAL POSITION.
1/8/2022 9:21:29 AM • 1996 Jeep Grand... • Answered on Jan 08, 2022
3answers
What will cause a burning smell coming from under the dash of a 1995 Jeep Grand Cherokee
Question moved from Computers to Jeep Grand Cherokee There is so much under there, it is impossible to tell. The most likely is a connector getting warm, but it could be so many things, even the radio, or the resistor on the heater blower.
12/26/2021 10:41:56 PM • 1996 Jeep Grand... • Answered on Dec 26, 2021
Alarm will not shut off so I can start vehicle, I
you should have a purple wire on the anitheft moduel ground it and it should disarm the alarm
11/24/2021 10:30:56 PM • 1996 Jeep Grand... • Answered on Nov 24, 2021
How do i shut the
lock and unlock the passenger door with the key, if the alram still sounds or u have a no start u will need to have the system scanned there is a problem with it.
11/13/2021 6:08:35 PM • 1996 Jeep Grand... • Answered on Nov 13, 2021
1996 jeep grand Cherokee rear liftglass wont lock
Open the door panel cover and grease or lubricate the window lifting mechanism. Apply rubber grease to the rubber rails.
5/15/2021 2:28:16 PM • 1996 Jeep Grand... • Answered on May 15, 2021
2answers
Jeep wont start checked connection and fuses
Check the battery, it sounds like it's flat. Try charging the battery to see if it recovers, but if the battery is about 3 years old or more it is likely to have failed and replacement is the only viable solution.
8/19/2019 5:42:09 PM • 1996 Jeep Grand... • Answered on Aug 19, 2019
Where is the fuel presure regulator at on a 96 v6
FUEL PRESSURE REGULATOR IS AN INTEGRAL PART OF THE FUEL PUMP MODULE CANT BE REPLACED SEPARATELY.
5/12/2019 6:09:44 PM • 1996 Jeep Grand... • Answered on May 12, 2019
Where is the gas regulator located on a 1996 jeep
You meant the fuel pressure regulator? It is located on the fuel rail and has vacuum attached to it. This is not the problem with your car tho. Check the ignition module, and the ignition coil.
5/12/2019 5:57:27 PM • 1996 Jeep Grand... • Answered on May 12, 2019
Why does my 1996 laredo have a severe clunk noise in the front end when slowing to a stop in Full TIME 4 wheel drive?
Sounds to me like you have bad universal joint bearings in a CV joint.
4/7/2019 7:27:26 PM • 1996 Jeep Grand... • Answered on Apr 07, 2019
1996 Jeep Grand Cherokee Logo
4,552 questions posted
Popular Products
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
View Most Popular
Grand Cherokee Jeep
  • Grand Cherokee Jeep
Most Popular Question
fireing order diagram
  • Cars & Trucks
