20 Most Recent
Legacy Audio ICE LA798 Car Audio Amplifier Questions & Answers
I have a 2500 watt legacy ice amp and im tryin to
If you amp is 1 ohm stable you can run + to +, - to - on each voice coil. Wire them into the box. Run +'s to +'s on amp, - to - on amp
Other wise. If it is a 2 ohm stable amp, you run two 4 ohm dual voice coils to the amp + -, + -
If the subwoofers are 2 ohm, run + - on only one voice coil to the box for each and run + -, +- for 2 ohm load on amp or + - bridged for 1 ohm load.
I hope that makes sense.
No Sound No Power
It sounds like part of the power switching circuit has failed. Your options would be to have it repaired/replaced or to try to repair it yourself. If you want to try to repair it yourself, visit the following link and then respond here. You will need to have the amp powered up and you'd need a multimeter to measure the voltage at several points on the board. A good quality photo of the circuit board would be helpful.
Basic Amp Repair
When I select the source
Would need some more info my friend, as when was the last time that it worked.. & what changes have we made on it since it was bought ... post the same to me & in the mean while try these ...
1.) Look for an option DVD menu to turn this safety feature off for ... Go to Setup menu and perform Position
2.) Try checking the connection from your car battery to the audio device...
By the way how old is the player ..
Thanks !!
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
