20 Most Recent
1995 Buick LeSabre Questions & Answers
I need a fuse and relay diagram for a 1995 buick
The fuses and relays are on the back fire wall under the hood.Just remove the plastic cover.This is not a fuse problem but more than likely a bad battery or charging system problem.Check the battery.Have it load tested and have your charging system tested also.Make sure all the cable connections on the battery and alternator are all clean and tight.Hope this helps.Good luck.
95 buick lesabre crankshaft pulley removal
i had used three bolts they have to be 6mm thik and like about 6 inches long then you install some flat washers by the head and use a regular crank pulley remover, you'll see three little holes inside the groevs at front side of pulley and there is where you install the bolts
I can't get to the license plate bulb in a buick
There should only ne two little screws on the plastic plate for the bulb. just unscrew and gently pull downward till bulb and harness are exposed. this should be a 194 bulb just pull out and replace with a new one.
95 buick lesabre door jam button that turns dome light on and off
I would think not correct. GM vehicles of that era were equipped with R.A.P(Random Auxiliary Power) it would keep certain systems on after shutting the car off.....(lights, radio, power windows) for up to 8 minutes. Unless you open the door, that would shut everything down. So if your power is staying on with doors open, most likely one or both of the relays in the RAP is bad
Were my heater fuse on a 1995buick lasabre
hello
u'd need a proper manual for this in my opinion
like there are plenty of dealers and online shops that deal in those..
you can get some free at reliable-store and it;s actually really illustrative
95 lesabre knocking from engine sounds like in
Unfortunately this sounds very much like a vehicles that has been neglected and has not had regular services. Take it to a repairer and ask for a quote to fix all the issues. Be prepared for bad news as it may not be worth repairing.
