20 Most Recent 2000 Pontiac Grand Am GT Questions & Answers
3answers
What are the torque measurements for the rocker
2.2L Engine & 2.4L Engines
These engines are not equipped with rocker arms. The camshafts directly actuate the valves.
3.1L Engine & 3.4L Engines
When install or connect the check the following:
- Pushrods and the rocker arms. Torque the bolts to 24 ft. lbs. (32 Nm). - Rocker arm cover using a new gasket. Torque the rocker cover bolts to 89 inch lbs. (10 Nm).
- Heater bypass pipe. Torque the screw at the water pump to 106 inch lbs. (12 Nm), the bolt at the cylinder head corner to 18 ft. lbs. (25 Nm) and the nut to 18 ft. lbs. (25 Nm).
About the INTAKE MANIFOLD...
Intake manifold nuts and bolts and tighten to 89 inch lbs. (10 Nm)
- Pushrods and rocker arms. Torque the bolts to 89 inch lbs. (10 Nm) plus an additional 30 degree turn. - Lower intake manifold. Apply sealant to the threads of the bolts and torque the bolts to 115 inch lbs. (13 Nm).
Exploded view of the upper and lower intake-3.1L & 3.4L engines
Fig. Lower intake manifold tightening sequence-3.1L & 3.4L engines
Hope help.
1/25/2023 8:58:44 PM • 2000 Pontiac... • Answered on Jan 25, 2023
2000 Grand AM GT has issues but wont throw codes
It sounds like you need a scan tool that will access all of the modules in your car. The traction and ABS codes will be stored in the ABS control module. As far as the miss, it should be in the ECU and accessible from any general scan tool.
9/15/2022 4:07:56 PM • 2000 Pontiac... • Answered on Sep 15, 2022
3answers
2000 grand am se abs light an trac off light and
If you had the car scanned with a generic OBDII code reader (Which is what they use at all the parts stores) this is probably why it is not showing any codes. You have "Vehicle Specific" codes. This means that the problem with your Check Engine light is not a problem that will generate a "generic" OBD code. A generic OBD code reader will not read codes from your Antilock Brake System or your Traction Control System at all... You need to have it scanned professionally by someone who has the proper equipment and software to access the Controller Area Network (CAN) in your vehicle.
9/15/2022 3:59:34 PM • 2000 Pontiac... • Answered on Sep 15, 2022
2answers
Coolant fans not coming on
coolant fan sensor
6/19/2021 6:46:03 PM • 2000 Pontiac... • Answered on Jun 19, 2021
4answers
Brakes and rotors making noise
Were metallic brake pads installed? If they were and are hidhly aggressive, yes. Give them a few miles to smooth out.
10/23/2018 12:48:03 PM • 2000 Pontiac... • Answered on Oct 23, 2018
2answers
Front end click
hi! there,
click noise on front wheel may also evident in
the suspension system when driving,these noises maybe produced by the springs and shock absorbers may either be a rattling noise or squeaks,Noises produced are usually caused by looseness of the parts, tightness of the parts and lack of lubricant.
have a nice day,don't forget to rate me ,thank's
5/21/2018 4:05:58 PM • 2000 Pontiac... • Answered on May 21, 2018
2000 Pontiac Grand Am has power wont start.
FUSE IS PROBLEM CHECK IT
3/17/2018 12:39:00 AM • 2000 Pontiac... • Answered on Mar 17, 2018
I have a 2000 Pontiac Grand Am and the interior stay on
Interior Lights Circuit Description By using a feature called inadvertent power control, the body control module (BCM) supplies power to all of the following components: • The courtesy lamps • The dome lamps • The rear view mirror reading lamps • The instrument panel compartment lamp • The rear compartment lamp The left front door ajar switch turns the interior lamps on through the BCM by grounding CKT 394. When the left front door is open, the switch is closed. This condition provides a ground and a door open input to the BCM. The BCM then grounds the following lamps through CKT 156 in order to turn the lamps on: • The courtesy lamps • The dome lamp • The rearview mirror lamps The right front door ajar switch and the rear door ajar switches turn the interior lamps on by grounding CKT 395 from the BCM. When the ignition key is removed from the lock cylinder, the interior lamps remain on for approximately 40 seconds. The BCM provides an interior lamps-on delay after a door is opened. The lamps remain on for approximately 40 seconds or until the ignition switch is turned to the ON position. The 40 second lamps-on delay reduces to 4 seconds if a door is opened within 2 minutes of the ignition switch being moved from the ON position. The interior lamps immediately turn off when the vehicle begins to move. The dome lamp OFF-DOOR-ON switch controls the dome lamp. When the switch is in the OFF position, the dome lamp remains off. When the switch is in the DOOR position, the dome lamp lights when a door is opened by the BCM grounding CKT 156. When the switch is in the ON position, ground is supplied through CKT 750. The rear view mirror reading lamps are controlled by the rear view mirror reading lamps switch or through CKT 156 from the BCM. Voltage is supplied at all times to the BCM through the INT LPS fuse. The BCM supplies voltage to the interior lamps through CKT 1732. Battery Run Down Protection When the ignition switch is in the OFF position, the BCM turns off the power to all of the interior lamps after 18-22 minutes. The BCM will reset the inadvertent power control relay output when one of the following actions is performed: • Open or close a door. • Turn the ignition switch to the ON position. • Turn off any interior lamps that may be on. • Press the power door lock switch/keyfob button. • Press the decklid release keyfob button. Courtesy or Dome Lamps Always On Step Action Yes No 1 Did you perform the Lighting Systems Diagnostic System Check? YES - Go to Step 2 NO - Go to Diagnostic System Check - Lighting Systems 2 Use the Scan Tool in order to command the courtesy lamps OFF. Do the courtesy lamps turn OFF? YES - Go to Step 4 NO - Go to Step 3 3 Test for a short to ground in the courtesy lamps control circuit (156). Refer to Circuit Testing and Wiring Repairs in Wiring Systems. Did you find and correct the condition? YES - System OK NO - Go to Step 7 4 Test for a short to ground in each door jamb switch circuit: • Circuit 394-Driver door • Circuit 395-Passenger door(s). Refer to Circuit Testing and Wiring Repairs in Wiring Systems. Did you find and correct the condition? YES - System OK NO - Go to Step 5 5 Test each door jamb switch for proper operation. Refer to the following: • Open switch with the door closed • Closed switch with the door open Refer to Circuit Testing and Wiring Repairs in Wiring Systems. Did you find a malfunctioning door jamb switch? YES - Go to Step 6 NO - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems 6 Replace the malfunctioning door jamb switch. Refer to Door Jamb Switch Replacement in Doors. YES - Is the repair complete? NO - System OK -- 7 Important: Perform the set up procedure for the body control module. Refer to Body Control Module (BCM) Programming/RPO Configuration . Replace the body control module. Refer to Body Control Module Replacement in Body Control System. Did you complete the replacement? System OK Instal the door jamb switch wire harness. Install the door jamb switch (2).
2/24/2018 11:50:09 AM • 2000 Pontiac... • Answered on Feb 24, 2018
2answers
I have a 91 chevy camaro rs v6 3.1 ran fine. I
check the crankshaft sensor for output
1/25/2018 11:37:04 PM • 2000 Pontiac... • Answered on Jan 25, 2018
Cruse control excelorates going up
any warning lights on?
1/16/2018 5:25:15 PM • 2000 Pontiac... • Answered on Jan 16, 2018
is there a question here? Haven't seen one so far
1/15/2018 9:35:53 PM • 2000 Pontiac... • Answered on Jan 15, 2018
2answers
Rough Idle
What size engine 2.4 or 3.4 L ? Dirty throttle plate , fuel injector's need cleaning , EGR valve sticking open a little , intake manifold leaking , IAC - idle air control valve passage carboned up . Idle Air Control Valve 007 Idle Speed Problems Scan Data for Idle
11/23/2017 12:28:35 AM • 2000 Pontiac... • Answered on Nov 23, 2017
Remote starter stopped working
I think you should go for owners manual for the repair of remote. May be this will help you. Pontiac Grand Am 2000 Owners Manual Download
11/20/2017 9:38:45 AM • 2000 Pontiac... • Answered on Nov 20, 2017
2000 pontiac grand am with
Have you bled the power steering? Jack up front so both front wheels are off the ground. start and warm up turn wheel from stop to stop slow until squeak stops make sure you keep filling it as you go. This may take a lot of turns. Let me know if this helps Mike
8/30/2017 7:14:15 AM • 2000 Pontiac... • Answered on Aug 30, 2017
2000 grand am gt headlights not working on dim
not working on dim ???? Low beams ?
7/21/2017 10:58:05 PM • 2000 Pontiac... • Answered on Jul 21, 2017
Service engine, abs, trac off
The service engine light does not affect the abs.You most likely have a broken wire in your abs system which is affected by suspension movement.A code reader which does abs codes will tell you which wheel circuit is turning on the abs light.When there is no abs available the track will turn off.
7/3/2017 12:33:45 AM • 2000 Pontiac... • Answered on Jul 03, 2017
2000 grand am se blower
It could be the actual switch maybe???
5/5/2017 8:35:03 AM • 2000 Pontiac... • Answered on May 05, 2017
0answers
2,020 questions posted
Popular Products
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
View Most Popular
Grand Am Pontiac
  • Grand Am Pontiac
Most Popular Question
front end click
  • Cars & Trucks
