20 Most Recent
1999 Volkswagen Passat Questions & Answers
Vw passat radio code
Passat 97 need to re-enter code ( 4 ) digit, however it shows the number 2 on the on screen when the radio is turned on.
Help. I need to know the steps to reset. thanks
None of my 4 windows
- This is a common problem with Passat's. I see you checked your fuses and relays so we will move on from that.
- You have a CCM Comfort Control Module in your car. This is a junction box of sorts that had the wiring for your electronics spidered through it. The placing of this was a real bad design because of it placement it gets water damage and the wires break etc.
- With the symptoms you are telling me I would bet this is your problem. It almost always is with the Passat.
- If there is any water underneath or any hints of water having been around the are then the CCM might need to be replaced. Check for broken wires etc loose connectors etc.
- If you have any comments please feel free to leave them here and I will respond to you.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
Diagram for relay 1999 passat
TTengo un passat1999 i me blokea la transmicion con tante mente le cambien la ecu s?lo duro unos d?as ilueguo boi vio alo mismo me gustar?a saber le puse el esc?ner i arroja selenoide pero lo probamos uno a uno i todo est?n vien
Wipers sticking in upright position on 1999 vw passat
It sounds like they are in the "service position" If memory serves correctly do this to get them out of the service position:Service position
To get into service position:
- After you turn your car off, tap the wiper stalk down. The wipers will move into the service position.
To get out of service position:
- To move the wipers back, switch on the ignition and tap the wiper stalk down.
