20 Most Recent
Legacy Audio LA1490 Car Audio Amplifier Questions & Answers
My 2000 watts legecy amp is not working whats wrong with it?
HelloPower light doesn't come ON, means there is no power enters inside the circuits. There will be an over current protection fuse, inside the amp, meant to blow up, if any short circuit occur inside the circuit board of the amp, or at outside speaker connection. You should locate this fuse and check it. it will be a glass cartridge type, slided into a fuse holder. You can detach it from its holder by a hard pull out. Just locate it, detach it from the fuse holder, and check it with a multimeter, set in Ohms range. The meter should show continuity. If there is no continuity, means the fuse is blown up. Before replacing the fuse, you have to check the reason for its failure. Without rectifying the reason, if you insert an other fuse and switch ON the set, the inserted new fuse also will blow up. Sometimes, it may cause to further component damage too.So check the circuit for any short. You must have thorough knowledge in electronics and all tools to do the work. If you are not aware in electronics, get this set repaired by any experienced service technician. OK.
Puedo conectarle 2 bajos de
Amigo, segun lo que lei, el amplificador es de 1400W 2 canales, asi que en teoria seria 700W por cada canal minimo, de alli para arriba puedes conectar lo que quieras, el control no es necesario (la marca no la conozco) y lo de la compra, como no pones de donde eres, te sugiero eches una visita a la pagina de www.mercadolibre.com de tu pais para que tengas referencias de precios...
Saludos desde Venezuela...
When I select the source
Would need some more info my friend, as when was the last time that it worked.. & what changes have we made on it since it was bought ... post the same to me & in the mean while try these ...
1.) Look for an option DVD menu to turn this safety feature off for ... Go to Setup menu and perform Position
2.) Try checking the connection from your car battery to the audio device...
By the way how old is the player ..
Thanks !!
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
