20 Most Recent 2001 Pontiac Grand Am SE Questions & Answers
Where is the trac on and off button located?
The traction off and on button is on the center face of the dash, justabove the radio and is the left button, the right button is your emergency flashers. It says ETS on the button.
11/7/2023 6:47:29 PM • 2001 Pontiac... • Answered on Nov 07, 2023
3answers
Can a fuel pump still be bad even if it still sounds like it works
The best way to tell is hook it up to a fuel pressure gauge and see if it has the specified pressure for your vehicle.
3/22/2023 10:39:33 PM • 2001 Pontiac... • Answered on Mar 22, 2023
3answers
Doesn't want to start - 2001 Pontiac Grand AM SE
Have you changed the fuel filter lately? If not change it!
3/22/2023 12:16:31 PM • 2001 Pontiac... • Answered on Mar 22, 2023
2answers
Pontiac Grand Am SE 3400 V6. Pulley identification for all drive belt pulleys on 3.4L SFI
Question edited for clarity and add some Capital letters. Question moved to Grand Am category (no year in OP). The diagrams and explanations are here https://www.2carpros.com/diagrams/pontiac/grand-am/2002 ..
7/17/2022 8:42:17 PM • 2001 Pontiac... • Answered on Jul 17, 2022
Air flow 2001 Grand Am
the mix doors in the heater assembly arent opening and closing right
6/15/2022 8:41:56 PM • 2001 Pontiac... • Answered on Jun 15, 2022
2001 grand am se jerking when changin gears trac off light on
Final drive speed sensor causing Trac light and rough shifting. Metal dust on the sensor. Have the transmission filter and fluid serviced. This should have been done at 60,000 miles. You may get an ABS light too. Service the sensor. Perform an OBDII scan for stored faults.
12/16/2021 2:09:16 AM • 2001 Pontiac... • Answered on Dec 16, 2021
2answers
How do i replace a camshaft sensor in a 2001 grand
Disconnect negative battery cable. Remove power ste
ering pump. Remove camshaft position sensor mountin
g
bolt and remove camshaft position sensor. To instal
l, reverse removal procedure. Tighten camshaft posi
tion
sensor bolt to specification.
12/3/2019 6:17:39 PM • 2001 Pontiac... • Answered on Dec 03, 2019
4answers
If my car takes 5w-30 can I use 10w-40 oil
Manufacturers recommend a particular grade of motor oil for the engine to ensure best operation and fuel economy. That said, yes, you can use other grades....but be advised that they must match the codes (such as SF-CC). 10W-40 is used by many drivers in warmer weather when they are driving long distances and subjecting the engine to highers temperatures and stress. I wouldn't recommend it be used in very cold weather as it will not provide as good a start-up lubrication as the 5W-30.
11/20/2019 10:55:34 PM • 2001 Pontiac... • Answered on Nov 20, 2019
How do I hot wire a 2001pontiac grand am se
you dont --thats the movies --if lost keys have a dealer or authorized locksmith cut a key using vin
8/20/2019 7:04:33 PM • 2001 Pontiac... • Answered on Aug 20, 2019
On the highway at higher speeds the car starts to
you have an engine miss, any time the check engine light starts flashing the engine is missing, should be an easy fix sounds like either a bad spark plug or a bad plug wire if you have the codes checked there should be a code telling you what cylinder is missing, but if i were you i would tune up the engine all new plugs and wires and filters......GOOD LUCK
4/18/2019 7:01:54 PM • 2001 Pontiac... • Answered on Apr 18, 2019
2answers
What is the spark plug gap for '01 grand am se
SPARK PLUG GAP IS 0.050
9/19/2018 1:54:16 PM • 2001 Pontiac... • Answered on Sep 19, 2018
4answers
Fuel pump location 2001 pontiac grand am
The fuel pump is in the fuel tank.Sit in the car.....turn on the ignition switch to run.....listen very closely to the rear of the car...or have someone kneel down by the back wheel.....you should hear a "prime cycle"......the pump running for 2 or 3 seconds if the key was off for 15 seconds before trying this.If you hear silence you most likely need a fuel pump.Before pulling the tank down....check for power on the gray wire at the fuel tank connector just ahead of the rear axle under the car.Check for power with a test light that will last for 2 to 3 seconds as you turn on the key to run.Power means you really most likely need a pump.No power means you may need a fuse or a fuel pump relay.
9/18/2018 12:21:38 PM • 2001 Pontiac... • Answered on Sep 18, 2018
2answers
2000 pontiac grand am. Has a high pitched squeal
take a bar of lava soap and BE CAREFUL use it to clean the belt and pulley groves THIS IS MAJOR DANGEROUS the cars motor must be running touch the inside of the belt for about 10 seconds with the bar of lave pumas soap .OR I WOULD PREFER you bring it to a shop and ask them if they will do the bar of lava soap trick to your surp belt.. bring your own bar let em keep it ... the groves in the pulleys get built up with rubber and will make your belt squeal . the lava soap in most cases will clean the groves .. cool huh.. did i help please leave feedback.. jay
5/30/2018 10:25:54 AM • 2001 Pontiac... • Answered on May 30, 2018
Car shifts hard
get the vehicle scanned at a repair shop. address the codes if there are any present. start there.
12/30/2017 5:01:21 PM • 2001 Pontiac... • Answered on Dec 30, 2017
I replaced a bad neutral safety switch on a 2001 Grand Am. The radio was out of the car at this time. Car cranks but will not start. Installed radio, it works, did not ask for code. Did the relearn
To check this kind of problem, first you have to know who is blocking you from getting start. Like your safety switch need to be adjust and verify with a scanner that can read the safety switch on and off state. Need more info to carry on with your problem. Good luck and don't listen anything from others before you have to proof each thing you do
12/19/2017 7:37:43 AM • 2001 Pontiac... • Answered on Dec 19, 2017
2001 Pontiac Grand AM SE Key wont turn
I suggest to go to the dealer to have a new key cut from code. Old one is probably worn out and no good to make a copy with.
11/9/2017 6:36:23 AM • 2001 Pontiac... • Answered on Nov 09, 2017
01 Grand Am (38k miles) stutters when trying to hold 50 mph. WHY?
Ignition misfire , spark plug's , spark plug wire's !
11/5/2017 12:12:53 PM • 2001 Pontiac... • Answered on Nov 05, 2017
I have a 2001 Pontiac grand am GT 3.4 Liter engine
Hello Anonymous.Not to difficult a job to do.You can find a step by step repair guide on Autozone's web site.http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f8036e843
9/3/2017 9:30:57 PM • 2001 Pontiac... • Answered on Sep 03, 2017
2answers
My car stalls when turning sharply at low speeds,
could be a bad power steering pressure sensor . This sensor inputs a signal to the PCM - engine computer when low speed an higher load on the engine ,such as turning , in return the PCM is suppose to raise the idle so it won't stall .
9/1/2017 9:08:55 PM • 2001 Pontiac... • Answered on Sep 01, 2017
2001 Pontiac Grand Am SE Logo
2,566 questions posted
Popular Products
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
View Most Popular
Grand Am Pontiac
  • Grand Am Pontiac
Most Popular Question
mean when brown sludge in anti freeze
  • Cars & Trucks
