20 Most Recent 1996 Mercedes-Benz C-Class Questions & Answers
How to disconnect anti theft on 1996 c280 mercedes
You cannot its all built into the ignition
4/6/2019 9:42:23 AM • 1996... • Answered on Apr 06, 2019
2answers
I changed the battery. The red & green lights on the rear view mirror flash & it won't start.
ok if your ecm has 2 plugs the wiring loom that goes from the ecu to the inside of the car not the one that goes to the engine.on the loomu need to open the cloth insulation theres a red wire with a thin blue line in it u hav to leave the wire a good distance 10cm or less cut it strip it and join a wire i can send you a video how to do it i had the same problem its not the key
1/19/2019 4:30:51 PM • 1996... • Answered on Jan 19, 2019
2answers
How do I replace my oil pan
clean area real good fix with jb weld
6/9/2018 9:05:48 PM • 1996... • Answered on Jun 09, 2018
3answers
Mercedes e class cannot open the boot
I have a e320 2003 model, the same has happened to me. I wondered if it could be the fuse but couldn't find a fuse that managed the boot.....
This problem is identical to the other post "boot wont open electronicaly by the boot release latch above the number plate, the boot release button inside the car or the key fob! I have to use the manual key to mechanically open it now."
4/10/2018 7:31:41 PM • 1996... • Answered on Apr 10, 2018
0answers
Mercedes C180 Air conditioner sensor problem?
Are you sure it won´t come on? It could be that you need to recharge the refrigerant gas in your car. If there is no gas it will only blow ambient air. I hope it helps
1/23/2018 1:37:57 AM • 1996... • Answered on Jan 23, 2018
2answers
My 96 C220 fuel pump does not have power, hence no
Is it a fuse or loose wire plug ? Thanks ????? Do guess test the electrical circuit for fuel pump . Voltage drop testing ! Testing Electric Fuel Pump Problems with Voltage Drop Test Know what's wrong ,not guessing .
12/15/2017 12:06:00 PM • 1996... • Answered on Dec 15, 2017
Oil leak from behind crankshaft pully.
I had my crankshaft pull oil seal chanfed years ago forvthe same thing if you have a puller to remove the pully the oil seal is easy to remove a screwdriver and a sorf mallet will change it
12/2/2017 8:32:22 PM • 1996... • Answered on Dec 02, 2017
C-220 1996, fuel pump went
Those are both O2 sensor heater codes. Since the codes come back, that would indicate the shop misdiagnosed the problem by assuming you had bad sensors when the problem is somewhere in the O2 heater circuit. Take it back to the shop and have them rediagnose the circuit. The tank fill problem is most likely caused by a problem in the EVAP system. Read the post below to understand what that it and how it works. http://ricksfreeautorepairadvice.com/evaporative-emissions-system-primer/ Evaporative Emissions System Primer Ricks Free Auto Repair Advice Ricks...
7/24/2017 4:22:27 PM • 1996... • Answered on Jul 24, 2017
0answers
3answers
Problem with Mercedes C 180 Elegance [auto] wiper
hi. the problem is from wiper temporysator.try to pul litle out that wiper buton.
3/10/2016 8:54:59 AM • 1996... • Answered on Mar 10, 2016
How do you open the trunk of a mercedes c220
use the key to open boot as long as the locks are there any door will open manually if you have removed the locks on the boot good luck unless you can get through the back seat into boot you have no chance
7/28/2015 10:03:12 AM • 1996... • Answered on Jul 28, 2015
Looking for mercedes benz car parts for my c180 elegance
i was looking for a alternator for my 250d merc go on goggle then find a part its free and within 10 mins got a reply found one delliverd 60 pounds next day thats good hope this helps
steve
7/11/2015 8:11:28 AM • 1996... • Answered on Jul 11, 2015
3answers
Center vents cold side vents hot please help bthibs
hello,good day,seems your recirculating pump need tobe check,ty
7/11/2015 7:57:44 AM • 1996... • Answered on Jul 11, 2015
My remote key fob wont open the doors when i
alicantecoli_3.pngtry this
6/19/2015 3:33:11 AM • 1996... • Answered on Jun 19, 2015
How to verify if the lock/unlock problem on MERC C220 1996 is due to remote battery?
THE ANTI THEFT MODULE IS TRIGGERED. SEE WHAT TO DO IN THE OWNER'S MANUAL.
6/17/2015 2:25:47 AM • 1996... • Answered on Jun 17, 2015
Location of the relay switch for the fuel pump for
in the boot under the spair wheel cover there are a few relays ner the battery i think its the one on the left
5/14/2015 5:52:58 PM • 1996... • Answered on May 14, 2015
2answers
Hello. I own Mercedes C180
When was last tune up? Plugs, wires, all fluids & filters? Especially fuel filter? I'd start there and run a good fuel system cleaner through it.
3/27/2015 9:24:18 PM • 1996... • Answered on Mar 27, 2015
1996 Mercedes-Benz C-Class Logo
660 questions posted
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
View Most Popular
C-Class Mercedes-Benz
  • C-Class Mercedes-Benz
Most Popular Question
slight leak ckeck oil level
  • Cars & Trucks
