20 Most Recent 2001 Mercedes-Benz C-Class Questions & Answers
Alarm will not deactivate. Car will not start
Call the dealer ,is the best answer with a immobilisor problem
5/23/2022 8:43:42 PM • 2001... • Answered on May 23, 2022
2answers
C240 mercedes key wont turn seems locked
I have a 2001 C240 with the same issue. I removed the positive battery cable from the battery and kept it off for 30 seconds then replaced it. Everything was reset and the key worked.
8/17/2021 2:39:11 AM • 2001... • Answered on Aug 17, 2021
2answers
08 dodge ram key FOB reprogramming
ATTENTION: You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.Click here to find a Locksmith in your area to program this remote.1. Enter your vehicle and close all doors.
2. Fasten your seat belt ( fastening the seat belt will cancel any chiming that may confuse you during this programming procedure.)
3. Place key into the ignition.
4. Turn the ignition to the ON position ( DO NOT START THE ENGINE )
5. Press and hold the UNLOCK button on a working remote.
6. Continue to hold the UNLOCK button, wait at least 4 seconds, but no longer than 10 seconds, then press and hold PANIC button.7. When a single chime is heard, release both buttons. The chime indicates the system is in program mode.8. Press and release both the LOCK and UNLOCK buttons, simultaneoulsly on the remote to be programmed.9. A single chime will be heard. The chime indicates the the remote was recognized.
10. Within 4 seconds of hearing the chime, press and release any button on the remote being programmed.11. A single chime will be heard The chime indicates the remote has been programmed.12. Repeat steps 8 to 11 for a total of 4 remotes.13. Turn the ignition to the OFF position or wait 60 seconds to exit program mode.
7/27/2021 9:54:34 PM • 2001... • Answered on Jul 27, 2021
COOLANT STOP, ENGINE OFF! with red colour temperature signal on the dashboard
I am driving a Mercedes E200Cgi. The dashboard gives me a red signal that says stop violent switch of engine
Thanks
Selloane
3/6/2021 3:10:21 PM • 2001... • Answered on Mar 06, 2021
ESP erroe code
hi,i have no doubt for there diagnose because they read on star diagnose,hoping that they read the actual values,you mention the fault is coming when you turning,maybe the steering angle sensor, if not mistaking,they have a sti,stated poor contact in wiring connection on control module
1/10/2020 9:49:38 AM • 2001... • Answered on Jan 10, 2020
2answers
Re-setting of cd changer
A couple of different possibilities here but this is a typical problem when it comes to the MB cd changers. Before ruling the cd changer bad, check the spring settings on the sides of the changer. Make sure they are in the 'H' position since it sits in the glovebox. The Mercedes cd changers don't have a reset button. 95% of the time its the cd changer that is bad when this scenario happens. Its caused by a linkage that gets knocked out of place internally of the cd changer. Also try not to use burned or homemade cd's as they can also cause the cd changer not to read the discs anymore.If your cd changer is brand new or a factory rebuild then the dealer should change it out no problem since MB cd changers are known for this problem. Also the version coding needs to done to configure the D2B fiber optic ring properly.
11/3/2019 11:05:27 PM • 2001... • Answered on Nov 03, 2019
2answers
Have a w203 c class constant battery drain been in
hello,hoping they right,maybe your front sam is switching a electrical consumer,even your ignition key is out,resulting your battery drain,if possible ,request your dealer a print out regarding front sam actual values and specified values for your reference,ty
8/14/2019 5:23:10 AM • 2001... • Answered on Aug 14, 2019
2002 c240 Mercedes wont accerate
Go to Advance Auto or Auto Zone and ask them to read the error codes. Then lookup those codes on the Internet or post them on https://mbworld.org/
11/9/2018 4:48:28 AM • 2001... • Answered on Nov 09, 2018
Mercedes radio removal
If it's an OEM radio Mercedes should have the code.. If it was replaced see if you can find the dealer that did the maintenance. It If you have the VIN# IT SHOULD LET THEM COME UP WITH THE SERIAL # AND HENCE THE CODE NUMBER.
11/3/2018 9:21:23 AM • 2001... • Answered on Nov 03, 2018
Mercedes-Benz C200 2001 suddenly stops
Get this manual online at www.reliable-store.com and get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
3/13/2018 5:53:44 PM • 2001... • Answered on Mar 13, 2018
2answers
Car wont start, Merc/Benz C240 2001
it could be a number of things. oil pressure switch, fuel pump relay or fuse. fuel pressure switch/regulator. something like this would help you find the fault https://www.ebay.co.uk/itm/Mercedes-Benz-MB-OBD2-CAN-BUS-Fault-Code-Reader-Scanner-diagnostic-scan-tool-UK/221097686022 just to read the fault codes.
2/10/2018 5:28:58 AM • 2001... • Answered on Feb 10, 2018
I have a 2001 C 270 CDI. Recently the turbo is
could be the boost sensor in intercooler system,,, or turbo actuator sticking
12/17/2017 5:16:16 PM • 2001... • Answered on Dec 17, 2017
The 2001 mercedes c320 won't start when it is
indications are that they are hard starting when cold indicates a problem ambient temp sensor or BARO sensor These sensors report to the ECM so that the correct air/fuel mixture is set for cold starting and running---sort of like the old fashioned choke pull have the fault codes read to determine where the faulty sensor is
12/8/2017 5:15:23 AM • 2001... • Answered on Dec 08, 2017
Whining Noise Near Rear Differential
indicates a fuel pump problem as that is the only thing in that area that is ignition controlled or possibly the EVAP system solenoid/ valve if it is in that area the frequency will be constant as the pump rpm is constant the noise could be a venting noise from the EVAP in in that area the distance of 15 km indicates that the problem is heat related as it take that long for something to over heat and cause the noise you may get an indicator by running the fault code
12/2/2017 5:12:07 AM • 2001... • Answered on Dec 02, 2017
I have a 2001 mercedes c180 coupe petrol 2 litre. Non start.
Follow normal troubleshooting procedures. Do It Yourself Diagnosis and Repair
11/15/2017 2:09:13 AM • 2001... • Answered on Nov 15, 2017
2answers
Hissing noise??
Hi Tommy Parry, not totally sure on your problem but would suspect the heater core which is a radiator device inside the passenger compartment. The hot engine water is feed through the fire wall into the heater core when you select heat on the heater. either the heater core is leaking which is an expensive repair or the pipes maybe rubber pipes have a hole in them and checking them in the engine bay especially the hose clamps in the engine bay where the hoses are feed into the passenger compartment may be a starting point.
10/2/2017 10:14:30 AM • 2001... • Answered on Oct 02, 2017
2001 Mercedes-Benz C-Class Logo
961 questions posted
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
View Most Popular
C-Class Mercedes-Benz
  • C-Class Mercedes-Benz
Most Popular Question
unlock radio mercedes c240
  • Cars & Trucks
