20 Most Recent 2005 Nissan Altima Questions & Answers
3answers
NISSAN ALTIMA '05 NO HEAT AT IDLE HEAT WHEN MOVING
I'm having the same problem, no heat at idle. I replaced the waterpump/both thermostats/belt and radiator. I'm still having the same problem. any ideas?
Thanks,
Kurt
11/29/2023 4:18:31 AM • 2005 Nissan... • Answered on Nov 29, 2023
2answers
2005 Nissan Altima. Roaring sound in rear when driving.
Question edited to what I think you thought you were saying. Question moved to model category from Televisions! Yes, almost certainly a wheel bearing. https://www.google.com/search?q=2005+Nissan+Altima.+Roaring+sound+in+rear+when+driving
1/10/2023 12:54:54 AM • 2005 Nissan... • Answered on Jan 10, 2023
2answers
05 nissan altima engine service soon light came on
As expensive as the parts are, I would only recommend changing what is faulty.
12/1/2022 11:28:10 PM • 2005 Nissan... • Answered on Dec 01, 2022
How do i get it out of limp mode nissan altima 2005
check fuse scan it told here 1000 times,and 1billion time on the web. and still true, the users manual even tells that too. (check engine lamp page)
10/15/2022 7:10:31 PM • 2005 Nissan... • Answered on Oct 15, 2022
How do i get my nissan altima out of limp mode 2005
too many chiefs spoil the soup unplug the battery neg lug for 1hour and pray it is not PCM destroyed
10/15/2022 7:08:36 PM • 2005 Nissan... • Answered on Oct 15, 2022
NISSAN ALTIMA A/C COMPRESSOR WILL NOT ENGAGE
I just fix my 2010 Altima The ac compressor did not engage the fans were both running all time when ac on The problem was the high pressure valve located on the driver's side on the condenser This valve controls both fans and compressor clutch
7/18/2022 12:09:23 AM • 2005 Nissan... • Answered on Jul 18, 2022
2005 Nissan Altima. Where is my transmission control module located please.
Question edited for clarity. Question moved to subcategory. By the battery. Click on the images tab https://www.google.com/search?q=2005+nissan+altima+transmission+control+module+location ..
5/19/2022 9:46:27 PM • 2005 Nissan... • Answered on May 19, 2022
The trunk lid on my 2005 altima will not stay open. how can I tighten it?
have you inspected rear support struts? they are readily available on line and parts store.
4/15/2022 5:17:09 PM • 2005 Nissan... • Answered on Apr 15, 2022
Where is the knocking sensor on a 2005 Nissan Altima V6?
Have you ever run out of oil? Do you change the oil and filter regularly? That sounds like big end bearings knocking. Knock Sensor location in the link. https://www.google.com/search?q=2005+nissan+altima+3.5+knock+sensor+location ..
2/19/2022 11:10:43 PM • 2005 Nissan... • Answered on Feb 19, 2022
2005 Altima front suspension
I've never seen a package deal on these parts. A rebuilt rack usually comes with new inner tie rods. But you'll need to buy new outer tie rod ends, stabilizer end links and you should really take this opportunity to replace the power steering lines. The deteriorate from the inside and can wear out the new rack much faster.
1/28/2022 5:26:41 PM • 2005 Nissan... • Answered on Jan 28, 2022
Why does my nissan altima 2005 not blowing hot air unless it runs over 1500 RPM 3.5 lt motor rad is clean also heater core is clean if it runs done the rd at over 1500 RPM lots of heat
take it to a radiator specialist shop as it indicates that there is an air lock in the cooling system that needs to be removed so that full coolant flow can be achieved
1/15/2022 3:17:39 PM • 2005 Nissan... • Answered on Jan 15, 2022
2005 Altima....key stuck in ignition
try the main fuse coming from battery to fuse box under the hood sounds like it popped.
11/22/2021 6:38:12 AM • 2005 Nissan... • Answered on Nov 22, 2021
05 Nissan Altima died on highway only code says crank shaft sensor replaced it still only cranks No start
You probably need to check the timing and make sure the marks line up properly.
8/30/2021 7:37:05 AM • 2005 Nissan... • Answered on Aug 30, 2021
2answers
I have a 2005 altima
Problems with Nissan 2005 Altima include-Crank shaft position sensor with ECU reset, ECU Factory reset from Dealer, Low Fuel pressure requiring fuel pump replacement, Replacement of ignition coils causing misfire during start-Catalytic Converter Recall-Oxygen sensor on exhaust-Leaking Valve cover gasket-Radiator failure due to plastic top & Bottom (Constantly adding water to reservoir?)
8/10/2021 1:07:56 AM • 2005 Nissan... • Answered on Aug 10, 2021
2answers
The radio says 'if you agree press ok' on the screen but you press ok and nothing happens what is wrong with it?
2 year old question and we are not associated with NISSON in any way
4/17/2021 1:20:46 PM • 2005 Nissan... • Answered on Apr 17, 2021
Why doesn't it rev or anything in drive?
Sounds like it is in some sort of 'Protect Mode'. You need to connect it to a scan tool and check the codes or Live Data
1/12/2021 3:02:05 AM • 2005 Nissan... • Answered on Jan 12, 2021
2answers
Nissan altima sunroof wont close all the way. It closes, but the rear of the window doesnt lift to create the seal at the back of the window. Any suggestions?
hi, With the car OFF and sunroof OPEN inspect all around the sunroof's frame. If nothing found that might be in the way (rocks, twigs, etc.), turn on the car CLOSE the sunroof and see if you can push it UP while closing to 'help it'. If it works, I'd just leave it closed 'til you can take it to the dealer/shop to fix it.
11/16/2020 7:41:51 PM • 2005 Nissan... • Answered on Nov 16, 2020
2answers
Where is the fuel pump relay located? Altima 2005
Its located in the IPDM box....remove the cover and you ll see a side with 4 relays close to the fuses and the other side 3line of relays,the relay in the middle is your fuel pump relay......hold the ipdm in position the fuses in the box upside....
10/9/2019 11:10:31 PM • 2005 Nissan... • Answered on Oct 09, 2019
2answers
2005 Nissan Altima 2.5s 4 cylinder. 1) When
no it could be air condition clutch that engage/disengage the air condition compressor and disengage it through the pulley or could be the pulley bearings one of them . also check the solenoid that controls that clutch .
have a good luck sir .
9/3/2019 11:31:22 PM • 2005 Nissan... • Answered on Sep 03, 2019
2005 Nissan Altima Logo
2,513 questions posted
Popular Products
2003 Nissan Altima
2003 Nissan Altima
1,450 Questions
2002 Nissan Altima
2002 Nissan Altima
1,306 Questions
2001 Nissan Altima
2001 Nissan Altima
569 Questions
1995 Nissan Altima
1995 Nissan Altima
534 Questions
1994 Nissan Altima
1994 Nissan Altima
410 Questions
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
View Most Popular
Altima Nissan
  • Altima Nissan
Most Popular Question
2005 nissan altima wont go into reverse
  • Cars & Trucks
