20 Most Recent 2007 Rolls Royce Rolls Royce Phantom Questions & Answers
Reset
Go to tire pressure and press reset on the status:tpm active
12/16/2014 7:18:40 PM • 2007 Rolls Royce... • Answered on Dec 16, 2014
What will wrong firing order do?
Ruin your engine
10/9/2012 9:04:45 AM • 2007 Rolls Royce... • Answered on Oct 09, 2012
How much site is required for installing RO in
i think no much ,but tell on workshop
7/16/2010 11:51:23 AM • 2007 Rolls Royce... • Answered on Jul 16, 2010
Rolls roycephantom headlightwiring diagam required
How much ofit do you need ?
7/1/2010 4:38:23 PM • 2007 Rolls Royce... • Answered on Jul 01, 2010
4answers
Brake job?
the best way to tell is by taking the tire off and look at the brake pads. if they are getting thin you should replace them.
7/1/2010 4:37:22 PM • 2007 Rolls Royce... • Answered on Jul 01, 2010
My 2010 rr phantom does not start somethimes even with new batteries but start after maybe half an hour after I let it rest .
Sounds like an electrical short. Check all hot and moving surfaces to see if they are coming in contact with wires.
1/5/2012 2:10:08 AM • Rolls Royce... • Answered on Jan 05, 2012
I have the engine light
Hello okt..... No problem. Just go to an AAMCO repair shop or most auto parts stores where they now scan the car's computer for free trouble codes and let you know what the codes mean. BE SURE to ask them to reset the computer too, as this will turn off the light. That way if the light comes on again you can scan again to see if it is a valid trouble code or just a jumpy sensor. Joe
Thanks for choosing Fixya!
1/6/2011 5:51:27 PM • Rolls Royce... • Answered on Jan 06, 2011
The battery is down and
The battery should be in trunk. Depending on the model, it should be under the spare tire. Just to be informative, look under the dash on the left of the steering column (U.S. models) and you should find a chrome (usually) lever which blends into the lines of the dash to be pleasing to the eye. Let me know if you need anything else. Happy new year.
1/1/2011 4:31:43 AM • Rolls Royce... • Answered on Jan 01, 2011
CHANGED FRONT&REAR PADS AND WEAR INDICATORS ON
PUT A SCAN TOOL TO IT BRING IT TO A DEALER
1/22/2010 3:05:20 PM • Rolls Royce... • Answered on Jan 22, 2010
Electronic ignition conversion for early Rolls Royce Silver Spirit
Kits. Choose the one that best fits your situation. PERTRONIX ELECTRONIC IGNITION KIT (ELEC5) ' Flying Spares Pertronix Electronic Ignition Kit (ELEC5): Part Number: ELEC5 Suitable for: Cars with Opus ignition (1974 to 1983) - Silver Shadow / Bentley T from VIN 22118 and SZ models up to 1983 (VIN 06969) Description: This aftermarket kit replaces the Opus ignition system with a Pertronix electronic ignition. It's a self-contained unit that eliminates the need for points and condenser. Installation is straightforward with only two wires to connect, and no permanent modifications are necessary. The hall effect sensor ensures durability and accuracy, even in harsh conditions. Benefits include increased spark plug life, improved fuel economy, and smoother engine running. Coil Replacement: When fitting this kit, you'll need to replace the coil with a 1.5 Ohms coil (such as COIL1 or COIL2). Compatibility: Suitable for late Silver Shadows, Bentley T, and early Silver Spirits up to chassis CH06969. Price: US$303.57 . Pertronix Electronic Ignition Conversion Kit (ELEC3): Suitable for: S3 and Silver Cloud III, as well as Silver Shadow & Bentley T1 before VIN 8742. Description: Converts your distributor from points to electronic ignition . Pertronix Electronic Ignition Conversion Kit (ELEC4): Part Number: ELEC4 Suitable for: Single Point Ignition cars from VIN 8742 to 22117 Description: Another option for converting your distributor from points to electronic ignition
4/7/2024 4:30:29 PM • Rolls Royce Cars... • Answered on Apr 07, 2024
Location of the starter relay om a rolls royce corniche 1979
rare car, and worse rare to the max service manuals from them. the manuals then are all made of paper, not digital until 2000 year. so buy the books googling, or ask the maker? of the car?
11/7/2022 12:47:24 PM • Rolls Royce Cars... • Answered on Nov 07, 2022
Where is the started relay on a 1979 Rolls Royce Corniche located
Rolls Royce, especially the older classic models, are known for having relays and solenoids mounted in strange places in the engine bay. You could find the starter motor and tracing the small wires back until you find the relay. I would also suggest you try some of the Rolls Royce owners forums as they will have a more specific knowledge of the wiring layout.
11/7/2022 11:40:58 AM • Rolls Royce Cars... • Answered on Nov 07, 2022
2answers
What is fuel pressure supposed to be for a 77 rolls Royce silver shadow 2
Have you checked for a broken fuel line around the carbs?
8/14/2021 1:19:31 AM • Rolls Royce Cars... • Answered on Aug 14, 2021
1996 (unknown model). Why can't the rear door on the driver side be opened?
vague information generic answer locking mechanism failure --linkages -linkage connectors failure
8/5/2021 11:37:33 AM • Rolls Royce Cars... • Answered on Aug 05, 2021
Change the temperature from Fahrenheit to Celsius on a 1986 rolls royce corniche ?
go see a local dealer .
11/25/2020 12:01:19 PM • Rolls Royce Cars... • Answered on Nov 25, 2020
Is there a trunk release for a 2006 rolls royce phantom other than the key
There is a trunk release button located inside the upper glove box compartment.
12/1/2019 3:30:39 PM • Rolls Royce Cars... • Answered on Dec 01, 2019
2007 Rolls Royce Rolls Royce Phantom Logo
10 questions posted
Top Rolls Royce Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Rolls Royce Expert? Answer questions, earn points and help others
View Most Popular
Phantom Rolls Royce
  • Phantom Rolls Royce
Most Popular Question
reset
  • Cars & Trucks
