20 Most Recent Sirius Stiletto 2 Portable Satellite Radio Receiver Questions & Answers
0answers
Hold switch is on?
You should just need to push the power switch down from the hold position. When it is pushed all the way up it is in hold mode. Sometimes that switch can break and affect the functionality of the Stiletto. If it is broken, you can contact a repair guy via email at [email protected] or you can buy a replacement at http://www.tss-radio.com/products/sirius-stiletto-2-live-portable-receiver-sl2pk1
6/29/2012 8:19:19 PM • Sirius Stiletto... • Answered on Jun 29, 2012
0answers
2answers
The button in the middle of the scroll dial does
some radio shacks have them
9/1/2011 4:52:10 PM • Sirius Stiletto... • Answered on Sep 01, 2011
2answers
Stilleto 2 error message
Truthfully, you will be better off just sending it back for a new one.
8/26/2011 2:06:09 AM • Sirius Stiletto... • Answered on Aug 26, 2011
My Stiletto 2 volume key on the side has quit
Hi c2koeh,
You can still fix it by opening the unit and try to clean the switch with a contact cleaner. You have to be careful when you take it a part there is many resistors and capacitor inside. If this fix did not work, I would suggest to replace it with a new one.
Hope it helps.
Thank you for using FixYa.
6/29/2011 2:18:07 AM • Sirius Stiletto... • Answered on Jun 29, 2011
Sirius Stiletto 2 constantly "acquiring signal"
This is an odd fix, but I read it yesterday after having the "Acquiring Signal" issue for a week. I put it in the freezer for 30 minutes, brought it back to my desk and now it works. I don't know why or how, but I am happy.
6/22/2011 5:49:09 PM • Sirius Stiletto... • Answered on Jun 22, 2011
My stiletto does not get
Does it get a solid signal when its in a docking station? Its likely that the internal antenna on the unit is disconnected. Antenna headphones would correct the issue, though they are not very durable at all. I know that our repair guy is able to fix the internal antenna, but I would ensure that is the issue first. Try plugging it into a home dock, car kit, or boombox to see if it works through one of those antennas.
6/16/2011 4:58:31 PM • Sirius Stiletto... • Answered on Jun 16, 2011
When i turn my stiletto 2 on it looks like it is
mgr2 ~ did you ever find an answer for this? I am having exact same problem!
10/28/2010 2:10:04 PM • Sirius Stiletto... • Answered on Oct 28, 2010
The unit picks up the
So when you listen and record at the same time, does it play in your headphones or through speakers attached? Did it used to record successfully or has it never worked correctly? These things are usually pretty straightforward, if it used to work correctly but now doesn't it may have some internal failure going on, if it never has worked, it almost certainly has a hardware issue.
Let me know and I can help.
Thanks
Tim
9/16/2010 10:56:54 PM • Sirius Stiletto... • Answered on Sep 16, 2010
2answers
Error message says to recover connect to a pc via
You have to download the recovery software from Sirius. Then you have to hold down the options and display buttons while turning it on. This should initiate the recovery process. This is all outlined in the manual with the recovery software. Having said that I wouldn't bother. These things are junk. I'm on my 8th one from warranty.
8/29/2010 4:14:42 PM • Sirius Stiletto... • Answered on Aug 29, 2010
3answers
SL 10 Antenna not detected
I've had this same thing happen to mine frequently - all I do to solve the problem is to remove the battery for about 20 seconds and then reconnect and power it back on. Always works fine after that (knocking on wood)! Hope this helps!
4/7/2010 2:30:51 PM • Sirius Stiletto... • Answered on Apr 07, 2010
Sirius Satellite Stiletto 2
My Stiletto got the same problem at around the same time. I have been reading many stiletto owners problems and see many of the same problems erupting at around the same time-mid to late February. I just spoke with a Sirius Representative who said the Stiletto 2 has been discontinued. Seems like a conspiracy to me.
3/27/2010 2:32:23 AM • Sirius Stiletto... • Answered on Mar 27, 2010
I have installed amicro SD card in my Stiletto 2
I don't know about you but I had to plug and unplug my 4GB PNY card in 6 times before I could get past the white dog. Only supports up to 8GB per manual.
3/6/2010 12:55:26 AM • Sirius Stiletto... • Answered on Mar 06, 2010
Sirius Stiletto 100 - can't record as of Jan 1 2010
Hard boot fixed it... (removed battery, put it back in... shoulda tried that a long time ago...)
1/6/2010 12:50:24 PM • Sirius Stiletto... • Answered on Jan 06, 2010
When I plug the stilleto into my car adapter it
I had the same problem with my home dock, it worked after unplugging the power to the dock for a few seconds
12/19/2009 8:12:52 PM • Sirius Stiletto... • Answered on Dec 19, 2009
Sirius Stiletto 2 Portable Satellite Radio Receiver Logo
42 questions posted
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sirius Audio Players & Recorders
Most Popular Question
unit picks up
  • Audio Players & Recorders
