20 Most Recent Logitech ClearChat Pro USB Headset Questions & Answers
You have to pair them.
Logitech... | Answered on Oct 22, 2017
Fixed it: the microphone on the headphone was switched off - it's a bit of a design weakness in the Logitech headset: it's easy to unintentionally turn the microphone off while putting the headset on. The lower half of the right headphone's central medallion is a button - indicated by a crossed out microphone icon.
Logitech... | Answered on Aug 29, 2016
Go to youtube to find http://www.youtube.com/watch?safe=active&v=KmzfJWVH6T8 go to start control panel then later go to mic or mirophone then later click or yes I agee then later let it download if cannot mean your sound is not load is put to 100% ok.
Logitech... | Answered on Jul 25, 2014
you have to go to settings then go the accessory settings then click on audio device settings where it says output device (next to it it should say logitech usb headset) click on it them put it tosystem default device
Logitech... | Answered on Jul 05, 2013
you need to access the audio device settings in the acessory menu and set both input and output to the same device ok :)
Logitech... | Answered on Dec 29, 2012
Probably a broken wire, try to isolate where it is at & then cut the wire, strip it back & re-connect & tape it up. To isolate where the break is hook up your headphones & pull, push & twist the wire all the way up to the ear piece till you find a spot where it cuts out or comes on & there is your broken wire.
Logitech... | Answered on Mar 17, 2012
The jack may be damaged or the entire system try to plug it with another device and check whether it is facing the same if it is your headsets are damaged.
Logitech... | Answered on Jul 20, 2011
if there is any corrosion in your connections using a pencil eraser to clean the contacts could help. Just take an eraser (like on the back of a #2 pencil) and erase the corrosion from the contact points, both on the headset and on the charging dock. Once the contact points look like new, give it a shot ... this might clean up the power connection and help you out.
If the connection where the headphones meet the charging dock has a spring in it (usually on the charging dock side of the connection) then you might have a worn spring. Sometimes pulling on the spring loaded connector (VERY Gently, to stretch it back to where it should be) can help ... but this is a last resort method as if you pull too hard you can pull the connection too hard and disconnect it inside the dock.
If neither of these works, you will probably have to either bring it to a repair shop and see if they can help, or buy a new charging dock (though if the problem is on the headphone side a new dock might not resolve the issue. If you are able to find a position that you can sit the headphones on the dock that will still charge the phones, you probably just have a dirty or loose connection, though.
Logitech... | Answered on Jun 07, 2011
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to solve your problem. Your Logitech ClearChat Pro USB Headset's volume will not stay at the level you turn it up to, and as a result it keeps rolling back down to a lower sound quality. Your volume control button doesn't solve the problem neither. Well, when a problem occurs, you should first troubleshoot where it's coming from. We will use a method called "Process of elimination". Your headset's volume has two controls: one control is on the headset itself, and the other control is located in the sound settings of the device you have your headset plugged into. With this thought in mind, lets go up to the problem explanation above. You said that the volume control attached to the headset didn't make a difference, this means the you can eliminate the hypothesis that it's the volume control causing this. The problem is coming from the earphone portion of the headset. Either a mute setting has been activated, volume is turned down real low or your headset is not the default device to receive sound input. The first part of the investigation is done; now, to get further into the investigation, you will need to connect your headset to your computer. This is where troubleshooting and solving the problem meet. Step-by-Step, I am going to explain to you how to get audio presentations into your headset. This device works with two Windows Operating Systems (Vista and XP) and one Mac Operating System (OS X). If your computer's operating system is Windows, open your Control Panel. Under the Hardware & Sound link, click Manage Audio Devices (for Vista users), and the Sound & Audio Devices link (for XP users). If your coumputer's operating system is Mac OS X, open your System Preferences and click the Sound link. In Windows Vista, click the name of your device, then click Set Default. Click the Properties button and increase the volume slider or unmute the volume if needed. If applicable, click the Apply button, then click OK. If the Apply button is void, just click OK. Click the Recording tab and perform the same procedures as you did before, only difference is that this will make your headset microphone the default recording device. In Windows XP, click the Audio tab and set the headset as the Sound Playback and Recording device. Increase the volume or unmute it if needed. When finished, click the Voice tab and perform the same procedures as you did before. In Mac OS X, click the Input tab and select the headset as the input device. If you still can barely hear anything, increase the volume slider. When finished, click the Output tab and repeat the same steps as before; only thing, you will be making this the sound output device, meaning the sound of your voice will be outputed from the microphone. Increase the volume slider if needed. You should be able to receive sound in and out of your headphones now. If we succeded, through this experience we have: troubleshooted where the problem was coming from, found a way to solve it and fixed the problem! Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again the next time you need assistance with something. Thank you and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Logitech... | Answered on May 28, 2011
Logitech ClearChat Pro USB Headset Logo
106 questions posted
Top Logitech Radio Communications Experts
Ekse
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Radio Communications
Most Popular Question
logitech headset m n a00008 will not
  • Radio Communications
