20 Most Recent
GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel Questions & Answers
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door
To remove most oven doors:
- Open door to the BROIL POSITION, where you feel hinge catch slightly.
- Place your hands on both sides of the door near the handle.
- Lift the door up and away from hinges.
- If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
- Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions.
Download a copy of your Owner's Manual and/or Installation Instructions
Wiring Schematic
I have found the best way to replace a part with many wires going to it is moving one wire at a time from the old one to the new one. If you have not already started moving wires you could go that route. As far as a schematic there is usually an envelope somewhere on the unit that has a wiring schematic inside. Typically they put that in the back of the control panel. If it is not there and you have a pull out storage drawer, pull the drawer out and check on either side of the cabinet to see if they stuck it on the side wall.
F2 is flashing and alarm is going off!
This is what the code means.
F2
For an unknown reason, the oven temperature has exceeded a preset threshold.
press the clear button for 10 sec. to try to stop it.
Good Luck and Please rate Fixya!
Jgep28
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this
problem the sensor needs replacement. If you want to be sure before replacing
the sensor then you can test it with a voltmeter for around 1100ohms....if it
reads more than this then it needs replacement however, if the reading is
around or less then 1100ohms then it is the control board that needs replacement.
Please get back to me if you have any other questions.
Kevin
I broke the glass top on my GE oven
I also dont see that part munber listed and the problem trying to find the glass for another brand is if the company uses a different thickness glass or the dimantions (sorry bad speller at times) are not exactly the same it wont work it could be exacly right left to right but if its a 1/4 ince to wide or what not it will not fit and keep the heat from escaping.
If you have a glass supplier in your area maybe they can cut you one
it has to be heat tempered with exactly the right bevels on the edges and the exact height&width That can be expensive
So sorry to say no nothing else would work
