20 Most Recent
Motorola Mobility i855e Pay-As-You-Go Cell Phone - Espresso Questions & Answers
I need unlock one motorola i856, you can´t
As you have not specified in particular what is the unlock code required for you, i am giving the ways to unlock all the codes
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If
your mobile is not an CDMA mobile , you can get the network unlock
code(NUC) by just contacting the current network provider customer care
department.It is free of cost.
The restriction code can be got
from your old service provider..This restriction code is kept to prevent
someone who stole the mobile from using it with another provider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
Do not pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above procedure works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4979448-need_unlock_motorola_razor_v3_from_optus
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact
your sim customer care department over phone. Its free of cost to get
the pin or puk no. If you cant contact through your phone get some other
phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Go
to the below link and you can confirm that the above procedure works
and there is a testimonial given by the customer too.
http://www.fixya.com/support/t3079596-sking_puk_code
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If
you try pin more than few predefined no of times your phone will ask
PUK code which can also be given only by your service provider which is
specific for each and every mobile number . Do not try PUK(new pin code)
code many times or else your sim will be blocked and you will need a
new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
SECURITY CODE:
If
it is lost nothing can be done. You need to flash your mobile at an
authorized service center which will reset the mobile memory and also
all the data inside the mobile will be lost.
12/14/2010 3:49:28 AM •
Motorola...
Answered
on Dec 14, 2010
I have an active nextel i710 and want to move sim
Remove the battery from the phone. Let it remain out of the phone for 10 minutes with the phone off. Replace the battery and turn the phone on.
This is a problem with the phone trying to read the SIM card after being in another phone. Be patient. It may take several minutes for the phone to read the SIM.
4/6/2010 3:02:37 AM •
Motorola...
Answered
on Apr 06, 2010
I just bought a boost phone i855 from a friend and
Turn the phone off. Take the battery out. Let it stand without the battery for 10 minutes. Install the battery and turn on the phone.
This problem is with the phone recognizing the SIM card. It may take a few minutes for the phone to recognize the SIM. Just be patient.
1/24/2010 2:09:35 PM •
Motorola...
Answered
on Jan 24, 2010
I855 text messaging
If this your motorola i855e is a Nextel phone, then not all the features will work very well if you put in a Boost Mobile sim card. Features like Texting, Web browsing are not likely to function very well or at all. Get a Boost phone for a Boost sim card. Cheers.
7/30/2009 5:03:05 PM •
Motorola...
Answered
on Jul 30, 2009
Can not get into camera, ring tones or media center...
Try a soft reset:
Take the battery out of the back of the device and wait 30 seconds before replacing battery. Boot up device and try to access your applications again.
If you are still experiencing problems, I would recommend contacting your pre-paid service for further troubleshoot.
Thanks.
3/27/2009 8:56:12 PM •
Motorola...
Answered
on Mar 27, 2009
Motorola i855 authentication error on java apps
Hello, first you need a usb cable. You have to go to motorola.com/iden and download the apps for i855. On the motorola site, download the usb software for your operating system. If you have windows vista as I have, you have to right clilck on the download apps utility and check to use windows xp service pack 2. Thats all I did and it worked. Then go in apps on the phone and download it and go to the factory presets and download. When you download the apps, you will have two in your folder. After you finish, delete the one thats not being used as its using up memory. Pebbles
3/14/2009 1:41:38 PM •
Motorola...
Answered
on Mar 14, 2009
Mortorola i855 Text messaging probs
I've had this phone for about 5 months and it STILL screws up, not only on this, but also on VIP, Boost Prepaid Premium, etc. I had to send my first phone back.
I'd strongly suggest returning it to the store and buying something else if you can! I haven't been happy with either Boost Mobile OR Motorola!
3/11/2009 8:59:34 AM •
Motorola...
Answered
on Mar 11, 2009
