20 Most Recent
Microsoft Wireless Controller for Xbox 360 (Blue) Questions & Answers
Today i bought "another" xbox
Hello.
You need to press the "sync" button, both on the console and in the controller. In the controller, this button is located near the LB, its small and round, and in the console, its right in the side of the memory card B slot. Also round.
When you press it in the controller, the lights will blink, spinning, same with the console. Both will sync this way. Let me know if it helped!
3/1/2011 8:53:23 PM •
Microsoft...
Answered
on Mar 01, 2011
My xbox 360 controller dosent
There's a little button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around thexbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I think there's a little symbol of air waves next to the button.
Try this it should fix your problem
2/28/2011 9:28:18 AM •
Microsoft...
Answered
on Feb 28, 2011
Console is not syncing with
are you using a play and charge kit, if so just try taking battery pack out and using normall batterys, as the play and charge kit does not carry any controler info to the xbox only voltage,
so it still acts as a wireless pad even when plugged in,
so what im saying is it could be a rubbish signal due to not having enough power charge,
if this does not fix it and you have tried the proper syncing process involving bothe the sync button on the xobx and the one on the controler its probably a broken controller, you should borrow one off a friend to see if that will connect to make sure not a faulty xbox
thanks
1/2/2011 4:03:29 PM •
Microsoft...
Answered
on Jan 02, 2011
Xbox360 not reading controllers
Re-Sync the controller, by pressing the small button at the top of the controller, and then pressing the small button near the memory card ports.
12/19/2010 12:38:15 AM •
Microsoft...
Answered
on Dec 19, 2010
I can't connect my Xbox360 Controller with
Have you tried more than 1 controller on the console?
Have you tried connecting it to the USB port via play n charge?
In some cases, the following part goes bad. It's the power button, but it also includes the receiver for the wireless controllers. When you hit Sync, this is the part that the controllers communicate with. It's not very difficult to install as long as you know how to open the XBox 360.
http://store.richspsxparts.com/orxb360rfmoi.html
10/23/2010 2:42:55 PM •
Microsoft...
Answered
on Oct 23, 2010
My wireless controller and system seems fine while
you'll need to either get a dvd remote or sign into xbox live and update it. If that doesn't work, you'll need to use a transfer cable to clear your system cache and then reupdate. If that doesn't work, you'll have to try another solution. Maybe the xbox is too old.
6/24/2010 5:29:48 PM •
Microsoft...
Answered
on Jun 24, 2010
I HAVE X BOX 360
there is a button on the guitar it is white should be were you hold it, then there is the same button on the x-box press that ans you should be good to go
8/8/2009 2:32:14 AM •
Microsoft...
Answered
on Aug 08, 2009
Wireless controller
you have to link controller to xbox under disk tray to right theys a small round button press this green rings flash, whilstflashing press xbox button on controller so it also flashes this will link them
4/26/2009 4:32:52 PM •
Microsoft...
Answered
on Apr 26, 2009
Guitar hero - defective
Look on the box that will tell you who the manufacturere is, it isn't Microsoft..... If you just bought it take it back for a refund..
The manufacturer is activision...
3/10/2009 11:38:52 PM •
Microsoft...
Answered
on Mar 10, 2009
Can not get controllers to
I'm not sure if this will help, but what I did was to connect a wireless controller to my XBOX with a cord/wire, then turn on my XBOX by pressing the middle button on the controller. This allowed my box to read the controller that way. You can then disconnect the controller from the cord then after, if you like. Unfortunately though, I have to always do this if I want the controller to be connected to my box, so that means EVERY TIME! I'm a little upset about it to say the least.
1/28/2009 4:08:31 AM •
Microsoft...
Answered
on Jan 28, 2009
Have the les paul guitar
try turning of your whole console and taking every controller out exept for the guitar and hold down the turn on controller button thingy that turns on the controller and try the game and see if it works if not i cant help im very sorry if that doesnt work
1/16/2009 2:46:32 AM •
Microsoft...
Answered
on Jan 16, 2009
