20 Most Recent
Microsoft Xbox 360 Console System Questions & Answers
Where can I find the IP address on the XBox 360
If you know your router's IP address, then here are the steps:If you still need assistance, feel free to post additional questions.To set your Xbox 360 console's IP settings
- On your console, press the Guide button on your controller, go to Settings, and select System Settings.
- Select Network Settings.
- Select WiredNetwork or the name of your wireless network, if you are prompted to do so.
- Select Configure Network.
- On the Basic Settings tab, select IP Settings.
- Select Manual.
- Select IP Address.
- Enter the unique IP address that you made up, and then select Done.
- Select Subnet Mask, enter your computer's subnet mask, and then select Done.
- Select Gateway, enter your computer's default gateway, and then select Done.
- Select Done.
How to setup Xbox Live
You will need some kind of internet connection so you will use either an Ethernet cord or a Wifi adapter. After you connect to the internet through your Xbox 360 you will have a 1 month free Xbox live trial. When the trial ends you will either use an Xbox live silver subscription which doesn't allow you to play games on-line, use Netflix, etc. Otherwise you would need to buy an Xbox live gold pass which is a better deal as you purchase a longer subscription. Thank you
What kind of problems can be caused from water
If it has water damage, than that means something is wrong with it. Water damage is the worst thing for electronics(as you probably know). If there is a chance of it still being wet inside dont turn it on(you turned it on didn't you?) Dude just get your 360 replaced. If it has water damage and still works, the life of your console is probably reduced greatly. Just try and get the new console if you can. Sorry if your hard drive got the wash too.
E203
From what I can find, it would seem your Xbox one is having trouble connecting to the Microsoft servers. It could be because of increased traffic, or an issue with your internet speeds.It is also possible, that the services provided by Microsoft, are not ready yet. It happens a lot during the first while of release of a new system.The PS4 is having simmelar issues.
Tray stuck open
The gears on the Xbox 360 have become misaligned. Here is how you fix it. If the tray is out all the way disconnect the power.
Step 1:
Locate the tab on the left side of the tray.
Step 2:
Lift the tab with a pen or equal and pull the tray out.
Step 3: power on the Xbox 360 and hit the eject button. When you here the eject "ding" pull the power. Now the drive is in eject mode and the cogs are aligned to take the tray.
Step 4
Gently place the tray back in and slight nudge to engage gears.
Step 5
POwer on xbox 360 and give another nudge to help the tray realign.
Step 6
Open and close the tray a couple times. To assure sucess.
