20 Most Recent
Cakewalk Music Creator 4 Questions & Answers
Serial number
CWMC-4.00-670692-073089
I don't know if it could help you or no, I find it by google for you and I hope it could help
Good luck
I just installed my copy
This link should be helpful they have an update for the audio. It's a patch that corrected the no sound.
http://forum.cakewalk.com/tt.aspx?forumid=18
Im useing cakewalk music creater
Be sure your computer is in either high-performance or low-latency power mode. Windows 7 likes to put computers in a power-saving mode that is great when running on battery but really works against you when working with high-demand software. There should be a battery/power icon on your task bar. Just double click this and change your power option to low-latency (preferred) or high-performance.
If this doesn't fully resolve the issue, follow my tip on speeding up your computer:
http://www.fixya.com/support/r5347471-speeding_up_computer_windows_xp
(slightly different for windows 7)
Im trying to download music creator 4 into my comp
Well, this is a simple problem.
You probably have auto-run disabled. So, go to "computer" and you should see your hard disk drives, and anything else connected or inside your computer. Once Music Creator 4 appears, double click it and it should run. Hope I helped in some way. :)
Matt P,
Computer/Gaming Relations Team.
Hello, I have the MIDI kit and it is pluged in,
In Device Manager (I am assuming you are using Windows XP) you will find your MIDI devices under Sound, Video and Game controllers. It is possible that the MIDI port has not been enabled in BIOS, I have had some PCs where this had to be done first. If Fruity Loops doesn't give you any available MIDI port to use it does not sound as though the PC knows it's there or has installed the driver properly. Start in Device Manager - if there's no MIDI port there or it's not working for some reason you'll have to fix that first.
Problems Trying to Run Program for First Time
administrator-right click on music creator and open as administrator.
click allow.
that all happend to me....so i called them and pitched a fit to the point
of them giving me all new codes. you can try thaT.
My music creator 4 wont let me register my product
HI ^^
take this latest version
download the full version of
Cakewalk Music Creator 5Release Name: CAKEWALK.MUSIC.CREATOR.V5-ADDICTION
Download:http://hotfile.com/dl/7508024/76ecddc/cmcv5.part1.rar.html
http://hotfile.com/dl/7508027/7bd05b2/cmcv5.part2.rar.html
http://hotfile.com/dl/7508026/7b1d1bb/cmcv5.part3.rar.html
http://hotfile.com/dl/7508028/4f36d59/cmcv5.part4.rar.html
Any troubles just let me know
plz rate it FIXYA ;)
Hi folks, my problem is when rec. audio the tracks
hi mate no worries heres a fix for ya lol in music creator 4 go to transport then click on recording options in the lower part titled "loop recording" click store takes in a single track you done no more bleeding i know that really sux
I have Cakewalk Music Creator 4 and EVERY time I
all you have to do to fix this is open music creator 4 go to options then audio click on the advanced tab and select mme 32(bit) then go to the general tab the click wave profiler once scanning your sound card close the wave profiler go to drivers and select your input driver (ie) line in/ mic line in, then the output driver (ie) speakers close the program re-open problem solved hope that helps
Lost registration code
You have to contact the supplier I am afraid as Fixya does not have that type of information
Sorry
