20 Most Recent Kingston 1GB Secure Digital Memory Card Questions & Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Kingston 1GB... | Answered on Oct 06, 2014
Do not format the drive. Try some photo recovery software to rescue the files on your digital memory card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Kingston 1GB... | Answered on Nov 20, 2013
In My Computer - Right click and format.
Kingston 1GB... | Answered on Oct 07, 2012
connect your camera to a compter
click start click on computer you should see your camera click to open you should see your pictures on the sd card select the ones you want to delece right click delete
hope it helps
Kingston 1GB... | Answered on Apr 05, 2012
I can help. What is not the problem, is the position of the switch entirely. With the SD card Face up and the tiny white plastic switch on the left side, should be slid toward the card edge connector (the shortest side). I know you may have done this and it still doesn't work. Here's why, On the opposite side of the SD card from the switch, there is a tiny "Notch" cut out.
Place a piece of tape, masking, electrical, sometimes transparent will work. Be very precise in placing the tape over the notch, but not over the brass connector on the opposite side. Then place it in your card reader, format it, read and write files to your desire.
This is a little known issue with the design of all SD cards. The notch forces them to work in camera's, MP3 Players, PDA's, etc. that are portable devices, but not in USB card readers or computers with SD reader slots.
The card reader with the SD card has this extra built in feature to protect copyrights (for some reason on blank cards), and makes it useless for custom applications. Once you have "Unprotected" the SD card, installed your files, then remove the tape.
If you get the same error again after applying the tape, add a second layer. Double check that you did not cover the connection edge, and the plastic tab is closet to the side you insert in the device you are using.
Sometimes it takes several tries, but it will work with patience. If you have existing files on the SD card, insert it, right click, select properties. Then remove the "Read Only" check by the box and try to delete or add files then. If it says Disk Write Protected, then check the tape again.
Kingston 1GB... | Answered on Jan 26, 2012
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones. Recommend that you try MiniTools listed on the site first.
Kingston 1GB... | Answered on Aug 19, 2011
Some have a small on off switch on the side make sure u have tried both ways.
Kingston 1GB... | Answered on Aug 15, 2011
Hello
What you need to do first is update your phone using nokia software updater so everything in your phone will be new then after updating put the memory card in it will ask for password ignore it then go to memory to format it after formating,u can see there is a set password set is to 12345,after setting there will be a new password then after thats done remove the password with 12345 then everything will be done.
THANK YOU
Kingston 1GB... | Answered on Jan 28, 2011
Follow same process for your card
Driver_1.00.01.zip file and save to your desktop. Use a file compression software to unzip the file located inside MyBook_vista_windows7_Driver_1.00.01.zip to your desktop. You will now see a file called "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" on your desktop. Double-click on "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" to launch the driver installation program. The wizard will display a message saying that it is ready to install the driver, click Next. Accept the license Agreement and click Next Click Install to start the installation of the drivers. The driver will be installed without further interaction and should take only a few seconds to install. When the installation is finished, click Finish to close the installation utility. Reboot the computer system before connecting the My Book Essential or Premium Edition hard drive. After connecting the My Book Essential or Premium Edition hard drive, Windows will automatically detect the unit and a new hard drive icon will appear in the My Computer window. Your My Book Essential or Premium Edition hard drive should now be ready to use.
Kingston 1GB... | Answered on Jan 24, 2011
1.Insert card into your phone but don't access it through phone. 2.Run FExplorer and Open the path C:\system. 3.You will find a file called mmcstore ,rename the file mmcstore.txt 4.Copy that file(mmcstore.txt) to your pc and open that file in notepad. 5.You will find your password in that file.
You can find the FExplorer from the internet..
Kingston 1GB... | Answered on Jan 18, 2011
Watch the video below and it will assist you to remove the write protection in your memory card
http://www.youtube.com/watch?v=Be_aHSlDFCU
Thank You
Kingston 1GB... | Answered on Dec 07, 2010
Check if the lock pin at the side of the SD is not set to lock.
Kingston 1GB... | Answered on Nov 26, 2010
There is a little slider on the right hand side of your memory card. If the slider is towards the bottom of the card the card is locked. When the slider is towards the top of the card your card is unlocked. So all you need to do is to slide the little slider towards the top of your memory card.
Regards, obliqueridge
Kingston 1GB... | Answered on Nov 12, 2010
install proper driver
Kingston 1GB... | Answered on Sep 10, 2010
scan the pen drive
it is probally corrupted,try putting in your computer and see if the computer can fix it for you,or else you might have to format it but you loose all your data this way
Kingston 1GB... | Answered on Sep 05, 2010
If you are asking about the write protect tab on the sd card. When the tab is pushed up closest to the contacts it can be writen to, when you slide the tab down it is then write protected (read only)
If this is not what you meant, just write back
Kingston 1GB... | Answered on Aug 14, 2010
Kingston does not distribute flash media with password protection. This password protection is a feature offered by most cell phones. To regain access, use the Lock Code assigned to the cell phone which your are using.
thanx
Kingston 1GB... | Answered on Aug 01, 2010
Kingston 1GB Secure Digital Memory Card Logo
70 questions posted
Top Kingston Electronics - Others Experts
WTF Chuck.....
WTF Chuck.....
Håkan Sterner
SANDIP MISTRY
SANDIP MISTRY
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Electronics - Others
Most Popular Question
forget memory card pasward
  • Electronics - Others
