20 Most Recent
JBL 5.1-Channel Home Theater Speaker System with 150W Subwoofer Questions & Answers
Connection system
hi,
connect satelite speakers to the amplifier and connect signal cable (RC pin) to the woofer from amplifer ie subwoofer out from amp. ok na.
-kanny
kanny-sounds.blogspot.com
I want dimensions of speakers &woofer of model
http://www.harmankardon.com/EN-GB/Products/Pages/ProductDetails.aspx?PID=HS%20200/230&accT=1&tsT=0&ovT=0
If this link does not work just look up harmankardon.com where you are
Hope this helps
Thanks for using FixYa
Friend gave me a jbl
You need two more speakers to get surround sound,ie> two front one center and two for surround,then you need a home cinema amp to run the speakers and decode the sound from your tv,sky,dvd etc,and the sub gives you your bass.
Hope this helps.
CABLE GUY.
Jbl sub 150
Make Sure you have your Audio cables Connected right. Meaning Red with Red and White with White.
How to open jbl on stage 200id?
To open the JBL On Stage 200iD, you need to follow these steps:
Remove the power adapter from the back of the device.
Turn the device over so that the bottom is facing up.
Locate the six rubber pads on the bottom of the device and remove them using a plastic opening tool.
Remove the six 1cm T-10 torx screws found under the rubber pads using a T-10 Torx screwdriver.
Open the device along its seam.
For more information, please refer to the JBL ON STAGE 200ID USER MANUAL.
https://www.manualslib.com/manual/788652/Jbl-On-Stage-200id.html
10/27/2023 9:59:32 PM •
JBL Audio...
Answered
on Oct 27, 2023
Problem with your JBL BoomBox2 speaker (or similiar) ?
Just found this out, after crazy searching & brainstorming.
So if your speaker suddenly goes silent or sound comes and goes, you can check this out:
At least the JBL BoomBox seems to have this integrated in its architecture so there's nothing we can do about it, complain to JBL : )
But to the problem: if the SOURCE of music/sound is too low, then the speaker may go into a "sleep mode" - silent. So ensure always your SOURCE of sound, connected to the speaker, has volume at least 80% to avoid this problem.
Hope this helps & no one needs to ditch and buy a new one ! : )
