If the unit is stock on highest volume and one channel only, the tact switch must be check, open the back cover, pull-out the board and spray an electrical contact cleaner into this switch while pushing on and off to clean its internal contact. You may also replace it all, it will not cost you much because it is one of the cheapest parts on the board.
Let me know if the symptoms still persist after the above solution had been done.
Jdvillanueva
1. Manually turn on the device (TV or Cable box) to be controlled. 2. Press and hold the P (Program) button until the red indicator stays on. Release the P button. 3. Press and release the desired mode button (TV or Cable). The red indicator blinks, then stays lit. 4. Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channels. If you accidentally overshoot the desired code, press the Channel Down button to backtrack through the library until the device changes channels. Pressing Channel Up changes the direction to forward again. 5. Press and release the Enter button to set the code. If the device does not have a Channel Up button, use Power instead. If you go all the way through the code library without finding the correct code the indicator blinks a few times then goes off.
Roku Communityhttps://community.roku.com > Remotes > td-p
Aug 28, 2020 - Solved: So I just purchased a voice remote to allow one remote for a Dynex TV in the office. I have cycled through so many brands without ...
7 answers · Top answer: All the line of sight was good. It's just that so many companies rebrand TVs that electronics ...
Please disconnect and then reconnect the 2 devices before moving forward. But you can wait 45 seconds before re-connecting the devices. If that does not work, please reference the manual for your contour box. Thank you.
Pull the mains plug and count to exactly 50 and plug it back in. This is a sort of a reset.
All televisions need a remote. Just buy a new one. Buy it for the specific model. Nobody buys universal remotes any more.
https://www.google.com/search?q=replacement+remote+control+for+dynex+tv
Question edited for maker and (what it is).
Question moved from Computers category.
Try are Factory Reset to set the picture settings to default. If that doesn't fix it, you will need a repairer or a new one. They are a 'cheap' brand.
https://www.google.com/search?q=dynamite+dx-l42-10a+reset+picture+settings
