20 Most Recent Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Questions & Answers
I have a Whirlpool Duet
Sounds like you have a failed water valve. Make sure your dryer is venting properly. If so, replace the water valve.
2/23/2018 5:53:32 AM • Whirlpool Duet... • Answered on Feb 23, 2018
Whirlpool duet dryer ring around the door keeps u hinging. They are metal and what I've tried is pushing them back in.
The clips are first secured to the ring. Then, the clips themselves go into holes around the door. They are somewhat spring loaded and you'll need to compress the fingers on the clips to remove them from the holes. Then, position the clips properly on the ring and push the slotted section (on the clips) onto the plastic tabs around the inside of the ring. Then, use a soldering iron to melt the tab heads so the the clips will stay on the ring. Then, just line up the holes on the dryer with the clips and start pushing them back into the holes. Remember, make sure the clips are aligned properly, else they won't line up with the holes. Good luck!
7/11/2016 4:57:10 AM • Whirlpool Duet... • Answered on Jul 11, 2016
The clothing do not toss around the drum and the clothes come out in clumps and wrinkled
You may be over stuffing. Try smaller loads and see if you have better results. Too much stuff in the dryer means that your clothes will have less room to move around, and if they're all crumpled up in the machine, they'll come out, well, crumpled-up-looking.
6/14/2016 7:30:56 AM • Whirlpool Duet... • Answered on Jun 14, 2016
Why does my dryer hum?
DRYER MAKES NOISES. A loose or worn BELT can make funny noises Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt. The glides on drum worn and making metal to metal contact. The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out. CHECK FOR LOOSE BELLOES inside the drum Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing. The blower: Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel. The bearings: The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process. The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it. The drum rollers or castors: It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them. GOD IS GOOD !!!!
4/26/2016 5:08:09 PM • Whirlpool Duet... • Answered on Apr 26, 2016
The wedges inside dryer, can they be removed and put back? I hear lots of change and things inside of them.
The baffles yes take off the top loosen the screws don't take them all way out rotate and shake loose baffle repeat for others
2/20/2015 7:39:18 AM • Whirlpool Duet... • Answered on Feb 20, 2015
0answers
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
3/9/2014 7:03:07 PM • Whirlpool Duet... • Answered on Mar 09, 2014
2answers
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
10/29/2013 3:49:22 PM • Whirlpool Duet... • Answered on Oct 29, 2013
When running it makes a scrapeing sound
Its most likely the blower wheel.
9/25/2013 4:58:47 PM • Whirlpool Duet... • Answered on Sep 25, 2013
The thermal fuse dose what on a kenmore dryer110.67032
It Keeps your heating element from getting to hot, If it burns out the heating element won't come on.
1/26/2013 3:11:19 AM • Whirlpool Duet... • Answered on Jan 26, 2013
Dryer gets hot not drying clothes
check your vent hose
5/20/2012 3:55:19 PM • Whirlpool Duet... • Answered on May 20, 2012
Dryer has power but wont start
Hello there and welcome to fixya Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
4/6/2012 3:25:35 PM • Whirlpool Duet... • Answered on Apr 06, 2012
Whirlpool front loader dryer does not heat up at all
Sounds like the heating element has gone. Ring around and find out the cost to fix. If the machine is a stand alone dryer and it is an older model it may be just as cost effective to buy a new one.??
3/13/2012 10:56:40 PM • Whirlpool Duet... • Answered on Mar 13, 2012
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
164 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
clothing not toss around drum clothes
  • Dryers
