20 Most Recent Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Questions & Answers
What type of connections does your tv have, hdmi, component? Match up the connection from the bose series 3 to your hdtv. I don't want to assume that your tv has hdmi, which would provide the best signal throughput & quality.
Bose Companion 3... | Answered on Nov 14, 2018
Static sounds usually indicate a failing connection. Disconnect and reconnect the plug several times to shine the contacts on the pins.
Bose Companion 3... | Answered on Jun 26, 2017
For technical help Call Bose.:
1-800-380-4831
Mon. - Fri., 8:30 AM - 9 PM ET
Sat., 9 AM - 6 PM
If you're not in North America see this site:
http://worldwide.bose.com/productsupport/en_us/web/home/page.html
Bose Companion 3... | Answered on Jun 05, 2016
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Bose Companion 3... | Answered on Jun 12, 2015
The control pod has specific design for the product therefore
I don\'t think there is any generic pod that comply with the product,
though you can find control pod for bose in ebay for about $10 to $50
71626100888?pt=US_Computer_Speakers&hash=item27f5b67898">http://www.ebay.com/itm/Bose-Companion-3-Series-II-Control-Pod-/171626100888?pt=US_Computer_Speakers&hash=item27f5b67898
how to connect bose 5.1 to mixers
Bose Companion 3... | Answered on Jan 18, 2015
Yes you can fix it but need a soldering iron and tin and the part that will change. Get everything in radio shack or similar store. If you don't now how solderin go to this link: http://www.youtube.com/watch?v=Rm28jkKGMz4
Good luck
Bose Companion 3... | Answered on Jul 31, 2014
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Bose Companion 3... | Answered on Jun 23, 2014
have same problem - swapped speaker leads and sound comes out of other speaker
Bose Companion 3... | Answered on Mar 11, 2014
The laser is failing. Just like in a record player there is a tracking gain adjustment inside but it is very touchy to move it. If anything is adjusted inside it may never work again. Perhaps resoldering some of those potentiometers, and perhaps other spots on the board may fix this. If the laser fails it is done.
Bose Companion 3... | Answered on Nov 13, 2013
Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
Popular Tags
56 questions posted
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
our bose companion 3 series 11 control
  • Audio Players & Recorders
