20 Most Recent
Garmin StreetPilot C550 GPS Questions & Answers
Forgot pin how can i reset
Try going to "tools" then "advanced" then "reset unit". Code should be either 0000 or 9999, depending on model.
1/24/2015 9:15:08 PM •
Garmin...
Answered
on Jan 24, 2015
It says the gps is turned off
go into the settings and turn off simulator mode... or the device is dead. call Garmin to see what they can do 1800-800-1020
8/9/2014 4:37:44 AM •
Garmin...
Answered
on Aug 09, 2014
Can't save truck profile garmin 560 lmt
get a new unit... the street pilot series is outdated and it's a miracle that your unit is still working at all. Celebrate that you have gotten 10+ years out of that unit and go get your self a Dezl or RV unit
8/5/2014 6:57:12 AM •
Garmin...
Answered
on Aug 05, 2014
My Garmin will not stay on. It starts to come on then shuts off.
Hi Paulette,Many Garmin GPS units that only get powered by the car charger / cradle suffer from this problem eventually. The fix is pretty simple. You didn't include your model GPS, but I think this may help just the same:Connect the GPS to a computer's USB port, or AC adapter that has a USB port and leave on for 8 hours (or over night). Disconnect and and turn on again. If you have a Nuvi that has a spring return sliding power switch - slide and hold it in the on position for 15 seconds before letting go. It should power up just fine. You do not need to hold the power switch like this again to turn it on.If the GPS starts acting like this again, simply repeat the process as often as needed. Eventually, the internal battery will no longer be able to accept a charge and will require replacement.Good luck!
1/31/2012 10:08:44 PM •
Garmin...
Answered
on Jan 31, 2012
